Rotary Cutter PTO shaft
/ PTO shaft #1
questadg
I borrowed a friends rotary cutter to use and the pto shaft is too short. I see that I can remove a roll pin and get a longer tube (outer) and that should do it. The tube is the newer triangle shaped deal (european?). Can anyone tell me where I can get the longer tube?
/ PTO shaft #3
You could try a pto extension. They don`t cost much. They are available at TSC and some parts places have them.
/ PTO shaft #4
How short is "too short"? Does it actually come apart when trying to hook it up? I ask, because the PTO extension mentioned only gives you about an extra 4 inches. During operation, you want the tubes to overlap by no less than 1/3 the closed length. Four inches might be just enough overlap to be dangerous.
//greg//
/ PTO shaft
Yes it does come apart. I engaged the PTO, lowered the cutter and the shaft came apart. I was thinking that I can get the outer (overlapping) tube at least 6 to 8 inches longer and that would help.
Volvo VNM (A63689)
Volvo VNM (A63689)
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
2020 VOLVO EC140EL EXCAVATOR (A65053)
2020 VOLVO EC140EL...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
MechMaxx Grinder Betsco Flail mower
MechMaxx Grinder...
