PTO SHAFT
/ PTO SHAFT #1
Cottonhawk
Oregon, USA
NH TC40DA, Canopy, Tiltmeter.
Any suggestions to make the PTO shaft glide smoothly? I tried to keep them greased but some of my PTO shafts glide fine and some get stuck often. None of my PTO shaft glide as smooth as I would like to see. How about hit the inside shaft surface with sand paper? Pros and cons? Will it cause the shaft surface to rust and stuck worse?
/ PTO SHAFT #2
If you can run your hand up and down a clean and lightly greased PTO shaft segment and NOT feel any burrs, I wouldn't waste any time with emery paper. The residual grit might even make matters worse.
The ones that are otherwise clean, smooth, lightly greased - and still stick ? Odds are they're bent
//greg//
/ PTO SHAFT #3
I have the same problem with the shaft on my cone spreader... I literally have to beat it onto the tractor with a hammer.
I've tried greasing, sanding, even drilling a hole in it to relieve any pressure/vacuum... nothing works.
/ PTO SHAFT #4
PTO Shaft - Every 20 hours
Disconnect PTOshaft from the tractor and slide apart. Clean
and coat the inner tube of the PTO shaft with a light film of
grease and then reassemble.
Type of Lubrication: Multipurpose
Quantity = Light Film
General stuff you already know...but maybe someone else could benefit from...
PTO shafts can be separated or pulled apart. The two parts are
made so that one part fits into the other. The PTO must be able to
telescope in and out to permit machine operation over irregular
terrain. If the parts become separated, they must be
re-assembled in phase to avoid placing extra strain on the
universal joints. Many shafts are designed to prevent this from
happening.
Check the enclosed for a picture of Phasing...
/ PTO SHAFT #5
Man..that can't be good for your tractor's PTO stub....:rolleyes:
If it is a triangular shaft, have you tried taking it apart and rotating it 60 or 120 degrees and sliding it back in?
/ PTO SHAFT
Thanks for the replies and suggestions.
I am going to check all my impliments PTOs to make sure that they are greased and operate properly before I put them away for Winter season. Is there any better lubricant than just grease?
/ PTO SHAFT #7
Plain old bearing/axle grease is probably the least expensive (and I assume most common) application. But my implements are exposed to the elements year round, so I had PTO shaft issues with grease running in the summer and stiffening in the winter. As such, I've found that white lithium grease (I got the aerosol can version) works much better in local temperature and moisture extremes.
//greg//
/ PTO SHAFT #8
The 3 lobe shafts I have will only go together in one orientation. It appears that the angular relation of the ridges is unequal. Any one else noticed this?
Vernon
/ PTO SHAFT #9
Vernon
They're designed that way Vern. No "phasing" issues with this type, but they can still bend. I had one straightened in a 75 ton press, but it still binds the last 4 inches or so.
//greg//
/ PTO SHAFT #10
I've seen them 'lemon' shafts twist too.. that makes sliding them a bit weird..
Soundguy
/ PTO SHAFT #11
I've got one particular pto shaft that's quite long. (on a hay elevator) grease doesn't seem to travel from the area where the zerk fitting is located. It requires seperating and manually greasing. Regular grease does "ok", but I've taken to using wheel bearing grease. It seems to stay on the job just a bit longer.
/ PTO SHAFT #12
Vernon
I think if you look closely, you'll see one of the corners has a flat and the other two corners are radiused.
/ PTO SHAFT #13
I just put together my first shaft today for a rotary cutter:
- first try, no grease: ugh, must be doing something wrong,
- second try, a dab of grease about 1-2 inches up both shafts (inside the large, outside the small) : get in about 5 inch, then stuck.
- third try, applied grease all the way down (about 12+ inches) with a long skinny stick - niclely spread thick: slides all the way in - no problem.
I guess the grease has to be applied as far as the expected overlap of the shaft pairs. I used that green bicycle grease.
/ PTO SHAFT #14
i have 2 new pto's that I am going to get the "joy" of doing this to soon....
I have 2 old pto's that i dont know if they have a shear bolt and will get to verify it was done properly. the 478 mower/conditioner has about a 9' pto shaft. I havent pulled it appart to see how big the connection is but it looked like a square shaft that may go a good section or all the length of the main run about 6' i think
any suggestions on old equip and adding a safty device for the pto? or am i just blind? (looking through the parts) it has a clutch plate? im wondering if this is a safty device. ug will have to see if I can get a couple manuals soon :/ hopefully i beat the first snow
GAYLEAN  130BBL VACUUM TRAILER (A67714)
GAYLEAN 130BBL...
WHOLE PART ROOM (A68842)
WHOLE PART ROOM...
CATERPILLAR D8T CRAWLER DOZER (A64279)
CATERPILLAR D8T...
PORTA POTTY (A67714)
213091 (A64276)
213091 (A64276)
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A66736)
2016 Chevrolet...
