wirlybird
- Joined
 - May 20, 2021
- Messages
 - 474
- Location
 - Oklahoma
- Tractor
 - John Deere 3038 E, John Deere 3032E, John Deere 756, John Deere X585, John Deere 332
I run a 5 foot brush hog on my JD 3032E.  I have used this cutter for years for lighter duty work.  Mostly just cutting field grasses on nice flat areas.
I do run a slip clutch PTO shaft. Clutch is adjusted correctly and is in good shape.
I usually run grade 5 or grade 8 bolts where the PTO shaft connects to the input shaft on the cutter.
This thing consistently breaks the bolts. I break one every week or two. I am not hitting anything like dirt clumps, sticks stumps etc.
The bolts all break at the same spot, which is about an 1/8 inch from where the threads meet the smooth shank.
The slip clutch fits snuggly on the gearbox input shaft so there is no wobble.
The gearbox is in good shape, spins freely and has no slop. Gearbox mount is solid and the gearbox is aligned straight.
I also run a 5 foot Woods BrushBull on the same tractor and have never broken a grade 5 bolt.
Any thoughts on this one?
