pto shaft question
/ pto shaft question #2
Yep, It's a standard series 4 PTO shaft. It expands.
BTW, I'm originally from the iron range...you ready for winter?:eek:
one more lawn mowing and one small brush cutting job, then pick up the yard and I am ready (well at least with outside stuff---cars get worked on inside)
/ pto shaft question #4
I cant see the two piece shield,
Look at where the shaft cover meets the right shroud. That line around the shaft cover is where the outer and inner shaft covers overlap. It expands from there. That's usually the end that goes on the tractor.
//greg//
2014 RETESA 210BBL CRUDE TRAILER W/ PUMP (A67714)
2014 RETESA 210BBL...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A67714)
2020 TROXELL...
2018 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A65057)
2018 CHEVROLET...
2015 Ford F-150 Ext. Cab Pickup Truck (A66736)
2015 Ford F-150...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A66736)
2022 Ford F-150...
