Pto shaft needed
/ Pto shaft needed #1
Cord
Veteran Member
Richfield, Wi
Resident Architect
I have an attachment that is missing half of the pto shaft. Basically I have the male portion of the shaft so I would be needing the tractor part. I'm not having any luck finding these on-line. Anybody have some suggestions on where to look?
The shaft would need to be between 18" and 21" long, the inner diameter would be 3/4" and needs to fit a standard 6 spline pto.
/ Pto shaft needed #2
You can try:
Central Supply & Rubber Company
109 N. 9th. St.
Omaha, NE 68102
Tel:# 800-444-8666
web-site: Central Supply
They carry a large inventory of hard to find parts/pieces for PTOs' including shafts, yokes, U-joints, couplers, adapters, etc.
They are good to deal with, and will send you a free catalog with your order if you ask them. Very handy catalog to have when looking for repair/replacement parts.
Good luck,
DT
/ Pto shaft needed
Thanks guys. Randy at Central set me up. Unfortinatly TSC is hours away from me so they are not a viable alternative. Never understood why they don't have more stores in Wisconsin.
/ Pto shaft needed #5
I had the same difficulty after purchasing a JD rotatory mower with the tractor portion of the PTO missing (fortunately the mower portion with the clutch was still there).
After some excellent suggestions here on TBN, I ended up finding the least expensive route to be purchasing a complete shaft and using half of it.
Anyone want 1/2 a PTO shaft? /forums/images/graemlins/grin.gif
Hope you get it worked out.
Shawn
2012 Ford Expedition SUV (A61574)
2012 Ford...
FUEL TRANSFER TANK & UTILITY BOX (A63569)
FUEL TRANSFER TANK...
2016 TAKEUCHI TB240 EXCAVATOR (A64279)
2016 TAKEUCHI...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
CASE TV450B SKID STEER (A64279)
CASE TV450B SKID...
