PTO Shaft Length
/ PTO Shaft Length #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
All of the PTO Shafts that I have seen advertised specify a "collapsed Length". How much will they "telescope"?
In other words, what size PTO shaft do I need if I've got 48 inches from my tractor pto to the gearbox on my cutter?
/ PTO Shaft Length #2
How much it extends is less important than its minimum length. This is a case of the shortest distance being a straight line, in this case the straight line being when the shaft is perfectly parallel to the ground. At any angle above or below that, the shaft will extend. So the parallel length is the critical length.
With no shaft installed, raise the cutter so that the PTO splines are level with each other. If in doubt, measure the distance from the tractor spline to the ground, then adjust the mower height so the transmission spline is at the same height. Then measure the distance between the rounded grooves that go around the circumference of the spline (they're the channels into which the shaft locks). You need a shaft that will collapse to that length without binding. I seldom find one "off the shelf" that fits properly. Typically I already know the groove to groove distance, get one just a little longer than I need, then cut it down to fit. Also typically, a new shaft should come with instructions on how to cut it down to fit your application. Simple job; hacksaw, tape measure, and vise. The hardest part of the whole job is just getting the PVC shields off and back on.
//greg//
/ PTO Shaft Length #3
Well, subtract the length of the ends/knuckles, and you have the tube length. You need to leave 3-6 inches of overlap, so that should get you close to the useable extended length.
As mentioned, longer is better as long as it fits, so don't worry too much about how long it can go, you want one that fits....
--->Paul
/ PTO Shaft Length #4
WARNING!!! When you fit a new PTO shaft, be sure it is not too long. Just measuring between the PTO and the implement is not good enough. The lenght of the top link makes a difference. Longer top link usually shortens the length between the PTO and the implement. Consider the movement of the implement if you shorten or add lenght to the top link. Then shorten the shaft an inch or two extra, just to be on the safe side. I had a breakedown on my tractor due to a too long PTO shaft. The PTO axle was pushed into the rear of the tractor, destroying the grove for the circlip that holdes the PTO in place, making the PTO axle slide out followed by 12 gallons of hyd. oil! I think I probably was lucky that nothing else broke, but I am not sure yet, the bearing at the end(Inside the tractor) of the PTO axle might have been pushed out as well, if tha is so, it is a big job coming.
(38) 8" - 11'L X 20" - 34" FLOOR TRUSSES (A60432)
(38) 8" - 11'L X...
2017 Ford F-250 Pickup Truck (A59230)
2017 Ford F-250...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
(20) WOOD PALLETS (A60432)
(20) WOOD PALLETS...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
