pto shaft connect question
/ pto shaft connect question #21
When you let your implements sit for a while make sure the pto hubs are not resting on the ground where they will gather dirt and moisture!
I tie the shafts to the top link attach point of the implement frame...even the implements kept inside.
/ pto shaft connect question #23
I'll bet you have a burr where the balls protrude into the yoke. Five minutes with a file will likely help. Also make sure the balls recess all the way inside. Dirt may have got in behind or if it is brand new there may be a burr keeping a ball from recessing in all the way.:)
/ pto shaft connect question #25
Sound like my Auger was built with the tiller , I had to fight it some also, the push me pull me thing and then the heavy Greece in the shaft, I was able to get the ring and bearings on the PTO but it just would not go on far enough to lock in,,,,used my leatherman file and hit the inside edges of the yoke and it was some what stiff but it slid on the rest of the way, did not want to file to much considering that it would wear on its own and loosen up.
00OOooo and tryin to get in there with a tiller and pull it and push it with that elmers Greece in the shaft, you must have been creating some new vocabulary, I was and it was only an auger, I raised the 3 pt. and flipped the top cover open over my PTO, i am guessing you were not so lucky with a flip top cover, just use a file down through the slots to clean up the edges some just so it will go on, it will get easier after each use,,,,,I use open gear spray Greece on all my pins and slip joints and Cat. 2 eyes, NAPA, comes out black but it is good stuff and works very nicely, if it is to sticky and slow moving parts back and forth just lightly tap a W-40 squirt.
GOOD LUCK :thumbsup:
/ pto shaft connect question #26
It's "grease", BTW...Greece is the country in southern Europe.
Autocorrect gotcha?
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 FREIGHTLINER...
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A63689)
Midwestern...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
