PTO safety???
/ PTO safety??? #1
s1120
Columbia county NY
87 Ingersoll 444, 84 Ingersoll224/'44 GreavlyL/60'sGreavlyL/49 Ford 8N
OK, now that I have my first tractor with a PTO, I'm thinking safety. I see the newer tractor have a sheld that goes around the PTO stub on the tractor. Now, my old 8N does not have one. Is this something that can be made up? Any standerd specs?
Also, when you buy a brushcutter, does the PTO shaft come with a cover, or would you need to buy that sepret?
Thanks for any help.
/ PTO safety??? #2
<font color="blue">...when you buy a brushcutter, does the PTO shaft come with a cover... </font>
All "new" implements will have the PTO shaft and guards included with the unit...
...it's the used/auction items mostly that won't have them, or may be missing components that may render them unsafe...
Even with the NEW plastic shields... always CONSIDER THE PTO SHAFT UNSAFE, so you will stay away from it while running...
/ PTO safety???
<font color="red">Even with the NEW plastic shields... always CONSIDER THE PTO SHAFT UNSAFE, so you will stay away from it while running...
</font>
Thanks John. I have read alot of storys here about the dangers of the PTO shaft, so I plan to show it a lot of respect, and do what I can to limit the hazards.
/ PTO safety??? #4
I'd remember the golden rule of don't mess with it unless it's dead (aka engine off)
/ PTO safety??? #5
Even the old N's had an after market pto shield kit. You may or may not be able to find one at
www.dennis-carpenter.com
Or you could make your own, and attatch it with the bolts that hold the check chains on.
Also, stores like TSC sell a pto screw on cap..
Soundguy
/ PTO safety???
Thanks soundguy. I have the DC catalog at home, no sheld. I will probably make one up.
/ PTO safety??? #9
One thing I use to think when I was hooking up the Pto shaft is what would happen if for some reason the PTO started spinning. With you hand up inside the shield you would not be able to get it out. From now on I always turn the tractor off when I hook the shaft up. Just something to think about.
/ PTO safety??? #10
If hes going to be custom making the pto shield anyway, It wouldn't be too hard to incorporate a door hinge on the top, and ball/detent pins ( or cotter/key pins ) on the sides, that way, you pull a couple pins and tilt it up.. or heck.. make the shield part pin on to the bracket.. and remove the whole thing when attatching / reattatching.
My NH has a shield that flips up... not too bad to mess with.
Soundguy
/ PTO safety???
<font color="red"> It wouldn't be too hard to incorporate a door hinge on the top, and ball/detent pins ( or cotter/key pins ) on the sides, that way, you pull a couple pins and tilt it up.. </font>
Thanks for the idea. /forums/images/graemlins/cool.gif Mabey just a simple latch of some sort will work.......... hmmm more to think about /forums/images/graemlins/smile.gif
2019 Ford F-150 Ext. Cab Pickup Truck (A66736)
2019 Ford F-150...
(2) 4 WAY WRENCHES (A64276)
(2) 4 WAY WRENCHES...
2006 CATERPILLAR 312CL EXCAVATOR (A65056)
2006 CATERPILLAR...
2015 CHEVROLET CAPRICE CAR (A66091)
2015 CHEVROLET...
CAT D6 Limb Sweeps (A68134)
CAT D6 Limb Sweeps...
285/75R24.5 Tire (A68134)
285/75R24.5 Tire...
