Rear Finish Mower PTO Safety Caps
   / PTO Safety Caps #1
OzWaz
Queensland
Kubota B6000
Could somebody please help with some advice regarding the removal of the PTO safety cap on a Kubota B1750.
I致e just bought a second hand B1750 and have downloaded and read the manual thoroughly while it does remind you to put the cap back on after using the PTO there are no instructions on how you actually remove it.
I have tried to work it out but it痴 not intuitive as to how it comes off.
Any assistance would be appreciated
Thanks
   / PTO Safety Caps #2
On my BX2200 the cap clips on. You squeeze the top and bottom to release the tabs.
   / PTO Safety Caps
Thank for the response.
I cannot see any Tabs other devices
Attached is an image showing the view I get from the rear
Regards
   / PTO Safety Caps #4
That looks home made. Try pulling straight back.
   / PTO Safety Caps
Thanks
it apparently has never been off as the machine was used with a deck mower underneath and it had plastic welded itself onto the housing . Just a little tap with a rubber mallet and a twist with multi and it came off no trouble - Thanks
alls good
BUT now I have a bigger which you may be able to help with if you don't mind. I owned a B6000 which died. However the PTO spine on the B1750 does not match any of my current implements. The B6000 had a 26mm shaft with about 20 micro robs the B1750 is larger and has only 6. is there any adapter that I can get so I can keep my existing implements?
   / PTO Safety Caps #6
[/QUOTE]
Glad the cap came off ok.
As to adapters for the PTO I do not know of any adapters. In my case I have a 40yr old Japanese roto-tiller with the same problem. I had the end of the PTO shaft hub cut off just forward of the U-joint and a six spline hub welded on.
This has worked well on a 5' tiller.
   / PTO Safety Caps #7
Thanks
alls good
Check with Tractor Supply (or Kubota dealer) for a PTO adapter.
   / PTO Safety Caps
Yes that is excellent solution and will solve the problem however I need to go the other way i.e. 6 to 18 (my model had 18 not 21) The site is not useful for Australian customers as it does not have a 'contact' facility and I need USA zip code to find a retailer to ask, but thanks for the lead I am on the right path now
Warren
   / PTO Safety Caps #10
Warren
Barco is your friend ...
Bare Co - P.T.O. Adaptors
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
20701 (A51694)
20701 (A51694)
UNUSED HURRICANE STAND ON SKID STEER (A51247)
UNUSED HURRICANE...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
