PTO rotation
/ PTO rotation #1
hagrant
Woodstock, NB Canada
454 foton
Is it normal for the PTO stub to rotate slightly without being physically engaged? I notice it is turning very slowly and it is not engaged.
/ PTO rotation #2
In some transmissions the fluid flow can cause the shaft to rotate.
Depends on your machine. I am not familiar with your machine. Is it clutch operated or HST?
The test would be to use a piece of scrap wood and see if it stops easily or keep turning. If it stops no problem. If it keeps turning check linkages and see if it is partially engaged.
/ PTO rotation
I just tried it and it stops when i put a small amount of pressure on it so it must be just the fluid flow. Thanks!
2017 JAYCO WHITE HAWK CAMPER (A67714)
2017 JAYCO WHITE...
2016 Nissan Frontier Crew Cab Pickup Truck (A66736)
2016 Nissan...
2011 UNKNOWN FRAC PUMP (A67714)
2011 UNKNOWN FRAC...
1977 WILSON ALUMINUM LIVESTOCK TRAILER (A67714)
1977 WILSON...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
