PTO REVERSER
/ PTO REVERSER #1
EaTmYtAiLpIpEs
I was told someone on here had a pto reverser for sale. please let me know ASAP. I need one immediatly.
/ PTO REVERSER #2
A fellow named Len from Schafer Tractor makes new ones for the Beaver. The input is 18 spline. He may do one for the Kubotas I do not know.
The one that was posted here a few days ago was original Satoh equipment for the beaver and bolts right up to the Beavers PTO case. It is in a box at UPS headed to its new owner.
/ PTO REVERSER
I called the place in texas. and they said they have never heard of a pto reverser.
/ PTO REVERSER #5
I am going to post a link to a site that I have no knowledge about. You can do some research into it and decide if you want to spend your money and take your chances. Either way, at least you will know what your looking for, as there are pictures posted. Not sure of the money conversion, but it is enough to scare you.
I thought you were considering making one?
I still think a hydraulic pto auger would be better than spending the money on a reverser. For no more attachments than are needed to be run, you can modify them to work. We did...
David from jax
Yenibiz en Detail PTO reverser
/ PTO REVERSER
I am gonna make one. I am looking for gears and stuff.
/ PTO REVERSER #7
If you have the ability and tools to make one, why bother? Seems it would be easier to just modify most attachments to run backward. I was being "set up" to build one, but the owner figured out how easy it was to just modify most of the stuff he used to run backwards, so he dropped the reverser idea. We didn't do a post hole digger, but that is a simple fix, by just going with a hydraulic unit. Changing an existing one over to hydraulics is probably also possible, if you already have you eye on a pto drive one.
He is currently enjoying the rebuilding of the his reverse running tiller, as it let loose something inside and the fun began!
David from jax
/ PTO REVERSER #8
Or you could buy a hydraulic PTO like I did and use that for all your PTO implements
2016 John Deere 6155R (A64119)
2016 John Deere...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
2012 UTILITY VS2RA 53X102 T/A REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
Caterpillar 299D3 (A64126)
Caterpillar 299D3...
