PTO Quick Connect
/ PTO Quick Connect #61
I'm with you. I am 68 years old . 7 years ago i had neck surgery , Degenerative Disk Disease. Nerve Damage, No Balance. Arms and Hands numb 24-7 . But i only have my tiller to hook up. Can not see spending BIG MONEY for something so simple .
You might change your mind if you had one of these dang things...
The weigh a ton too.
/ PTO Quick Connect #64
Good for you 0LDPIL0T. I turned 80 last month. I'm slower but more determined. The major changes I've noticed - I'm not as limber as I use to be. But that's OK. Retirement allows me to go any darn speed that works.
/ PTO Quick Connect #65
txndncowboy - checking around and I see where one of the major players in the bush hog business now has a "drive shaft sling". Holds the shaft up at the correct height for easier hook up.
Doesn't make much difference - the shaft is HEAVY if you are fortunate enough to get a quick hook up OR becomes VERY HEAVY if you have to fiddle around making connection.
TWO things you could make a fortune on now. Quick, easy, simple PTO hook up AND mouse repellent that works 100% of the time and lasts forever.
/ PTO Quick Connect #66
For me to hook up my brush hog the drive
shaft is approx 5 ft long and I don't have any
problems so far and I'm past 82 going on 83
Granted I can't life 400 lbs any more like I
could in my younger days but can still handle
50 pounders. I slowed down when I had
shingles for 6 months leg and back hurt so
bad didn't do anything but not back at it.
Anyone suffering from arthuritis 1000 mg
of VIT "C" every day helps my wife to keep the inflamation down and she don't have the pain.
willy
2020 CATER PILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATER PILLAR...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
Informational Lot - Financing (A63688)
Informational Lot...
Marcrest BSP449 (A64127)
Marcrest BSP449...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
