pto question
/ pto question #1
Ianvictor
Bobcat 320
hello, hoping someone can inform me as to wether it is possible to reverse the pto output on a iseki tx13000f ? i have looked at the various operating levers but cant see one that says 'pto reverse'. thank you. Ian
/ pto question #2
No reverse, Only goes one direction.
/ pto question
Ok, thank you for the quick reply.
I figure the best thing is maybe to try the tiller with the tines as they are and see how they perform?
I have read a number of posts suggesting that forward direction tilling is better for riding over any obstacles, small rocks and pebbles and that is the the direction the tiller is operating but the tines are facing the opposite way?
Or can you tell me have I got it wrong?
Cheers Ian
/ pto question #4
If you were standing on the drivers side of the tiller, the rotation of the tines is CCW yes?
/ pto question
Sorry a bit new
/ pto question
Yes, that is correct they move CCw from the drive side, but should I expect the point of the tine to hit the soil first?
/ pto question #7
I'm not sure. Can you show us a pic? It seems like everything is ok. Bolens does not have a backaswards pto direction. Unless you have a left handed 'tiller, you should be ok.
/ pto question
iseki tillerpic.jpghopefully can? not the best picture but hopefully you can see the position/direction of the tines,and of course that they go anti clockwise.
cheers Ian
edit ok thanks for your replys, i have looked on youtube at different tillers in operation and they all appear to turn in the same diection and with the tines in the same direction as mine? so all should be good? its just not the directions i expected the tines to operate!
ok thanks again Ian
/ pto question #9
Great, glad you worked through it. Much better than walking with one eye closed.:thumbsup:
/ pto question
Thanks again Topbuilder, your help is much appreciated, cheers Ian
/ pto question #11
Do not feel bad there are some tillers that came from Japan back when Gray market Tractors were coming over that did run clockwise. There is a great amount of information on here for the asking. Welcome to the site.
/ pto question #12
AND some of those tractors had PTO's that ran backwards too...
At least, backwards from todays standard...
SR
/ pto question #13
I knew nothing about tillers years ago and was surprised the tines actually rotate to help move the tractor forward. Seems like most things work against the tractor's motion (brooms, cultivators, plows, etc.) whereas tillers actually need the tractor to hold it back. Kinda opposite what you might expect I guess so I understand where you're coming from.
2008 23ft. Zodiac Hurricane Inflatable RIB with 2007 25ft Myco T/A Aluminum Boat Trailer (A61574)
2008 23ft. Zodiac...
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A59914)
2015 FREIGHTLINER...
300 Gal Fuel Tank (A64127)
300 Gal Fuel Tank...
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
2006 Lexus ES 330 Sedan (A61574)
2006 Lexus ES 330...
EZ Trail 3400 (A63688)
