PTO Question
/ PTO Question #1
chado613
Kingston, Ontario, Canada
IH 624, IH B414, Kubota RTV 900, Kubota M7060
When the rear PTO is stated as 540/1000, what does that mean ? That the PTO can operate at 2 different RPMs? Or is there actually 2 different PTO "shafts"
ALso does the 540 RPM mean at idle that is the speed its rotating?
Thanks in advance
/ PTO Question #2
Thanks in advance
Yes it means it can run at two different rpm speeds and no it's not at idle. It usually would be between 2000 and 2500 rpm, depending on the tractor to achieve the 540 pto speeds.
On my tractor I need to change the pto spline and shaft to run 1000 rpm attachments.
/ PTO Question #3
These pictures might help, the splines are different for the two speeds.
He is holding the 540 rpm end.
/ PTO Question #5
Your tractor's tachometer should have a mark on it that says PTO. That's the revs you need to turn the engine to turn the PTO at 540 rpm.
/ PTO Question #6
Think the rear PTO is 540; whereas, any mid PTO is about double that.
Doubt you can get 1,000 rpm on the rear PTO. Your tachometer probably has a marking for 540 rpm. My JD 1025 actually tells me on the tachometer what the PTO speed is when when it's running.
Ralph
/ PTO Question
Unfortunately when I inherited the tractor (It came with the farm when purchased), All of the gauges are not in working order.
/ PTO Question #9
The value of the 1,000 rpm pto is that it puts less stress on the pto shaft and its joints.
The energy the shaft transmits is a direct function of the rotational speed.
Of course the energy the implement needs does not change and the gear box on the implement needs to be designed to to handle the stresses it will see.
If you take an implement and pto shaft designed for 540 and start running it at 1,000 expect serious, loud expensive problems in a hurry.
Dave m7040
Club Car Emergency Cart (A64557)
Club Car Emergency...
2022 EZ-GO ELITE...
SHOPBUILT MESH BOTTOM TRAILER (A64278)
SHOPBUILT MESH...
2020 Ford Fusion Hybrid Sedan (A64557)
2020 Ford Fusion...
CATERPILLAR CB13 DOUBLE DRUM ROLLER (A65053)
CATERPILLAR CB13...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
