Pto pump flow help??
/ Pto pump flow help??
Thanks J J that's pretty much what info I was looking for. I don't have any ideal as to who put the setup together I bought the tractor with the hoe already setup it had 100 hrs on the meter back when I bought it. I've used it all these years the way it is, works pretty well it's just slow. We just bought a new house and more land and will be using the hoe a lot more now so I thought It would be a good time finally to check on doing something with it.
/ Pto pump flow help?? #12
Do you have optional PTO speed like 1000 rpm?
If so, you can get 9 GPM at 2000 psi .
No I sure don't , I will have the hoe back on this week end for a couple thing I need done. I'll get some pics and measurements, and see just how much room I have may be possible to come up with some type of speed increaser for a lot less than a new pump.
/ Pto pump flow help?? #14
Your tractor hyd is 7 GPM, so I think I would use the tractor hyd.
You will then have more GPM's and pressure to the BH.
Set your BH relief to the same as your FEL valve.
If you can find a 4.5 ratio gear box you can use the 540 PTO to increase the so called PTO pump to the rated 2500 rpm
Since you have 27 PTO HP, you can run the tractor PTO pump to pump 20 GPM at 2000 psi.
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
(INOP) 1991 GMC DUMP TRUCK (A59823)
(INOP) 1991 GMC...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59906)
2016 FREIGHTLINER...
2007 JLG 600S Manlift (A61166)
2007 JLG 600S...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
