pto problem 2150
/ pto problem 2150 #1
smanna
upstate ny
cub cadet 2150
I have a 2150 with about 250 hrs on it. When I engage pto, engine stalls out. Starts and runs fine, new pto switch put in last fall, also new wire harness.
/ pto problem 2150 #2
Remove deck and check all spindles; make sure they all spin freely; also check idler pulleys. Make sure belt is routed correctly.
/ pto problem 2150 #3
Check your safety switch for the seat. I have a 2165 that did the same problem, would stall out or not come up to speed. After changing PTO's, PTO switch, I found out the switch under the seat to be bad. I cheated and put a jumper wire on instead of new switch. Maybe this will help for you.
/ pto problem 2150
I checked both suggestions, and the problem turned out to be with the safety switch. Up and running again, thanks for the help.
Kelly-Creswell Model C Walk Behind Paint Striper (A66734)
Kelly-Creswell...
AGT QA 72" Rototiller (A64912)
AGT QA 72"...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
2019 Kubota RTV X900 4x4 Diesel Utility Cart (A66734)
2019 Kubota RTV...
2012 Ford F-250 Crew Cab Pickup Truck (A64556)
2012 Ford F-250...
