pto problem 2150
/ pto problem 2150 #1
smanna
upstate ny
cub cadet 2150
I have a 2150 with about 250 hrs on it. When I engage pto, engine stalls out. Starts and runs fine, new pto switch put in last fall, also new wire harness.
/ pto problem 2150 #2
Remove deck and check all spindles; make sure they all spin freely; also check idler pulleys. Make sure belt is routed correctly.
/ pto problem 2150 #3
Check your safety switch for the seat. I have a 2165 that did the same problem, would stall out or not come up to speed. After changing PTO's, PTO switch, I found out the switch under the seat to be bad. I cheated and put a jumper wire on instead of new switch. Maybe this will help for you.
/ pto problem 2150
I checked both suggestions, and the problem turned out to be with the safety switch. Up and running again, thanks for the help.
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2006 PETERBILT 379 (INOPERABLE) (A67714)
2006 PETERBILT 379...
17in. Bucket w/ Teeth Excavator Attachment (A68183)
17in. Bucket w/...
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
2017 MAC Half Round T/A End Dump Trailer (A68183)
2017 MAC Half...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A66736)
2016 Peterbilt 579...
