PTO Noise
/ PTO Noise #1
BCNU
Hopkinsville,KY
Kubota B2630
On my B2630 with 8 hours I turned on the PTO today for the first time with no implements hooked to it, just to check it out and it makes a rattleing noise. Is this normal ? The faster the RPM'S the less it rattles. It dose this in all 3 PTO posistions. Dose anyone elses make this noise or is this something I should have the dealer look at ?
/ PTO Noise
/ PTO Noise #3
It may be normal without a load on PTO. Do you have a PTO driven attachment that you can put on tractor?
/ PTO Noise #4
/ PTO Noise
I don't have any pto driven attachments at this time to put a load on it. I had just engaged it for the first time to check it out. I figured it should not make any noise.
/ PTO Noise
/ PTO Noise #7
I'm not sure but I suspect it may be an over running clutch that is rattling because there is no load.
/ PTO Noise #8
/ PTO Noise
Anyone with a 2630 or 3030 that dosen't have a pto driven attachment hooked up willing to turn there PTO on and see if it makes a rattleing noise or not. If it is normal I won't worry with it but if its not I want to get it in to the dealer to get it checked out. Thanks in advance for any info!
/ PTO Noise
John Deere 410D Backhoe (A62679)
John Deere 410D...
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
UNUSED WOLVERINE PALLET FORK FRAME (A64281)
UNUSED WOLVERINE...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
SHORTWOOD LOG TRAILER (A64276)
SHORTWOOD LOG...
