PTO Noise
/ PTO Noise #1
BCNU
Hopkinsville,KY
Kubota B2630
On my B2630 with 8 hours I turned on the PTO today for the first time with no implements hooked to it, just to check it out and it makes a rattleing noise. Is this normal ? The faster the RPM'S the less it rattles. It dose this in all 3 PTO posistions. Dose anyone elses make this noise or is this something I should have the dealer look at ?
/ PTO Noise
/ PTO Noise #3
It may be normal without a load on PTO. Do you have a PTO driven attachment that you can put on tractor?
/ PTO Noise #4
/ PTO Noise
I don't have any pto driven attachments at this time to put a load on it. I had just engaged it for the first time to check it out. I figured it should not make any noise.
/ PTO Noise
/ PTO Noise #7
I'm not sure but I suspect it may be an over running clutch that is rattling because there is no load.
/ PTO Noise #8
/ PTO Noise
Anyone with a 2630 or 3030 that dosen't have a pto driven attachment hooked up willing to turn there PTO on and see if it makes a rattleing noise or not. If it is normal I won't worry with it but if its not I want to get it in to the dealer to get it checked out. Thanks in advance for any info!
/ PTO Noise
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59912)
2025 PJ CC162 T/A...
UNUSED WOLVERINE HYD STUMP GRINDER (A64281)
UNUSED WOLVERINE...
Rake Master CR-72G (A64119)
Rake Master CR-72G...
(2) 380/85R28 TIRES W/ (10) LUG WHEELS (A64280)
(2) 380/85R28...
BUNDLE OF 8" - 10" I-BEAM UP TO 9' & (2) 2" & 6" (A64280)
BUNDLE OF 8" - 10"...
JRB 52" HANG-ON WHEEL LOADER FORKS (A63276)
JRB 52" HANG-ON...
