PTO Noise
/ PTO Noise #1
BCNU
Hopkinsville,KY
Kubota B2630
On my B2630 with 8 hours I turned on the PTO today for the first time with no implements hooked to it, just to check it out and it makes a rattleing noise. Is this normal ? The faster the RPM'S the less it rattles. It dose this in all 3 PTO posistions. Dose anyone elses make this noise or is this something I should have the dealer look at ?
/ PTO Noise
/ PTO Noise #3
It may be normal without a load on PTO. Do you have a PTO driven attachment that you can put on tractor?
/ PTO Noise #4
/ PTO Noise
I don't have any pto driven attachments at this time to put a load on it. I had just engaged it for the first time to check it out. I figured it should not make any noise.
/ PTO Noise
/ PTO Noise #7
I'm not sure but I suspect it may be an over running clutch that is rattling because there is no load.
/ PTO Noise #8
/ PTO Noise
Anyone with a 2630 or 3030 that dosen't have a pto driven attachment hooked up willing to turn there PTO on and see if it makes a rattleing noise or not. If it is normal I won't worry with it but if its not I want to get it in to the dealer to get it checked out. Thanks in advance for any info!
/ PTO Noise
2009 Toyota Camry Hybrid Sedan (A61574)
2009 Toyota Camry...
UNUSED WOLVERINE HYD TRENCHER (A64281)
UNUSED WOLVERINE...
2016 JOHN DEERE 317G SKID STEER (A64279)
2016 JOHN DEERE...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
Chevrolet 2500HD (A63688)
Chevrolet 2500HD...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
