PTO Model 4035
/ PTO Model 4035 #1
ehoffmeyer
Mahindra 4035
Neither PTO control switch has any effect on stopping the pto shaft from running.
I even disconnected the 2 pin connector on the PTO control solenoid and the shaft continues to turn.
I sure could use some help figuring this one out.
Thank you.
PS
I now call this tractor the "Mahindrance"
Eric
/ PTO Model 4035 #2
Is it running with full power or just spinning from oil or clutch drag,
will it run an implement under load when shut off.
/ PTO Model 4035
Running with full power and it responds to increases and decreases in the hand throttle.
It acts like it is locked to the "on" position and I can't turn it off.
Thank you for responding!
Eric
/ PTO Model 4035 #4
ever find out what it was? must have been a short somewhere. did you try pulling the fuse?
/ PTO Model 4035
No. The electrical connection at the PTO solenoid is disconnected, pulled off not on the solenoid yet the PTO shaft continues to run at power/RPM levels commensurate with the throttle position.
Eric
/ PTO Model 4035 #6
Have you removed the actual solenoid valve not the coil but the actual valve,
it could be hung open.
