PTO Making noise when engaged
/ PTO Making noise when engaged #1
Madison, Virginia
Kubota L3200 HST
Just noticed when I engage the PTO on my Kubota L3200 HST I get a loud rattling noise that seams to be coming from below between my feet. I unhook the PTO shaft from the sicklebar but the noise is still happening although a bit less. I have check the oil, and hydraulic fluid and all seems good although the oil looks very black (need to change soon). Any thoughts to what to check in before taking the tractor in for service? If I do not engage the PTO, all sounds good and things like the FEL work great.
Not sure. All I know is that I move the PTO lever to on position then release the clutch slowly with rpms low and it engages. When I move the PTO lever to off position or depress the clutch it disengages the PTO although it takes a minute or so to fully stop spinning.
/ PTO Making noise when engaged #4
Was thinking (W.A.G.) maybe if it had one, it's not fully releasing.
Does the tractor's pto shaft feel ok? No loose bearings?
Does the noise (rattle) change pitch with the rpms?
Or is it more random?
All seems tight and nothing loose. When I increase the rpms, the sound gets softer for sure.
/ PTO Making noise when engaged #6
Check the adjustment on the PTO engage cable...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
UNUSED IRANCH MINI SEMI-AUTOMATIC QUICK CHANGER (A62131)
UNUSED IRANCH MINI...
7888SFL (A61567)
7888SFL (A61567)
2019 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNFL0KG646154 (A61165)
2019 Ram 5500 4x4...
PAIR OF DIAMOND PLATE DBL AXLE FENDERS (A62130)
PAIR OF DIAMOND...
UNUSED WOLVERINE SWDB-11-84W HYD DOZER BLADE (A62131)
UNUSED WOLVERINE...
