PTO length , need a few inches to Cat 1 between tractors
   / PTO length , need a few inches to Cat 1 between tractors #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I just got a Kubota B7200, and have it sorted out except for a poor electrical connection at the fuel level sender.
I tried to hitch up the McKissic chipper /shredder, only to find the PTO shaft is too long. (fitted to the Hurlimann 435)
Question???
Pat's easy change or a "harbor fright" quick hitch to add the needed two inches of distance between the PTO stub and the implement?
$100 for one, $180 for the other... Not really an issue, but the need is only a few inches. ;-)
   / PTO length , need a few inches to Cat 1 between tractors #2
If the $80 is not an issue go w the quality.
   / PTO length , need a few inches to Cat 1 between tractors #3
Go with the Pat's as you will find the HF will not fit all your implements without some modification.
Another option (and cheaper) is if your only PTO implement is the chipper, cut the shaft to accommodate the shorter distance. But if you plan to use the chipper on both tractors, that will not be much of an option :laughing:
   / PTO length , need a few inches to Cat 1 between tractors #4
A quick hitch has other conveniences, but if you just need to shorten the shaft, then shorten the shaft. It's about 5 min work with a hacksaw, or 30 seconds with a saws-all.
Shortening the shaft is NOT an option. The implements would not be usable on the larger tractor.
   / PTO length , need a few inches to Cat 1 between tractors #6
Then spend the $80 extra bucks and go with Pat's. The quality will be far superior.
   / PTO length , need a few inches to Cat 1 between tractors #7
The Pat's is excellent equipment, and will be the most versatile.
   / PTO length , need a few inches to Cat 1 between tractors #8
On the larger tractor you run it within "a few inches" of the PTO shaft pulling apart?
2015 TRANSCRAFT/WABASH 48X102 STEEL FLATBED (A58214)
2015...
MISC TIRES (A54757)
MISC TIRES (A54757)
Case-IH 370 Steiger (A57148)
Case-IH 370...
LOT: (200 approx.) Gallons of Chevron Delo TorqForce SAE 10W Hydraulic Oil (A59076)
LOT: (200 approx.)...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
