PTO length , need a few inches to Cat 1 between tractors
   / PTO length , need a few inches to Cat 1 between tractors #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I just got a Kubota B7200, and have it sorted out except for a poor electrical connection at the fuel level sender.
I tried to hitch up the McKissic chipper /shredder, only to find the PTO shaft is too long. (fitted to the Hurlimann 435)
Question???
Pat's easy change or a "harbor fright" quick hitch to add the needed two inches of distance between the PTO stub and the implement?
$100 for one, $180 for the other... Not really an issue, but the need is only a few inches. ;-)
   / PTO length , need a few inches to Cat 1 between tractors #2
If the $80 is not an issue go w the quality.
   / PTO length , need a few inches to Cat 1 between tractors #3
Go with the Pat's as you will find the HF will not fit all your implements without some modification.
Another option (and cheaper) is if your only PTO implement is the chipper, cut the shaft to accommodate the shorter distance. But if you plan to use the chipper on both tractors, that will not be much of an option :laughing:
   / PTO length , need a few inches to Cat 1 between tractors #4
A quick hitch has other conveniences, but if you just need to shorten the shaft, then shorten the shaft. It's about 5 min work with a hacksaw, or 30 seconds with a saws-all.
Shortening the shaft is NOT an option. The implements would not be usable on the larger tractor.
   / PTO length , need a few inches to Cat 1 between tractors #6
Then spend the $80 extra bucks and go with Pat's. The quality will be far superior.
   / PTO length , need a few inches to Cat 1 between tractors #7
The Pat's is excellent equipment, and will be the most versatile.
   / PTO length , need a few inches to Cat 1 between tractors #8
On the larger tractor you run it within "a few inches" of the PTO shaft pulling apart?
SKID STEER ATTACHMENT RAKE (A58214)
SKID STEER...
Mobile Transformer and Power Substation Portable Power Supply (A55302)
Mobile Transformer...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
Topcon RL-H4C Laser w/Tripod & Grade Stick (A59076)
Topcon RL-H4C...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
