Generator PTO Generator
/ PTO Generator #1
anderson1
Arkansas
Jinma 224
Does anyone have any experience with PTO powered generators?
I am currently building a house and want to incorporate an alternate electrical supply in the event we loose power. I was considering a stand alone generator but thought I would be able to save some money with a PTO generator and utilize my tractor to power it. I have a Jinma 224 (22 hp).
Any thoughts or recommendations would be appreciated.
Jim
/ PTO Generator #2
No experience here, however I do recall a post about tractor RPM changes under varying generator loads. I'm not sure what problems this would cause. Sorry I can't be more help.
/ PTO Generator #3
Jim,
This has been discussed hundreds of times...
Do a search for "PTO Generator" be sure to change the time frame in the search as it defaults to 1 week.
Sit back and get comfy, there will lots of reading to do!
Good luck!
/ PTO Generator #4
I have a Generac 4000 watt portable generator. I have had to use it about 4 times in 2 years during power outages. I ran it all night once until it ran out of gas. You wouldn't want to run your tractor out of fuel.
Here's a few things to consider:
You cannot expose a generator to foul weather such as rain. You would have to run the tractor inside a ventilated barn or other shelter.
Power always goes out at a bad time. It might not always be convenient to hook the gen up to the tractor.
You might wan to use the gen where your tractor isn't.
I'm sure my BX1500 could run a small PTO gen but I think the portable has more pros than cons.
Dean
/ PTO Generator #5
Jim,
Here is a link t a long discussion going on now in the Attachments forum
CLICK HERE
/ PTO Generator #6
</font><font color="blue" class="small">( You cannot expose a generator to foul weather such as rain. You would have to run the tractor inside a ventilated barn or other shelter. )</font>
Very easy workarounds.. Farmers have been doing this since pto gensets existed.
First.. my ptogen is mounted on a pallet, and the pallet is on a 3pt carrier. A 'medium' siged dog house fits perfectly over my 12kw pto gen when you turn the opening side toward the tractor for the pto shaft to enter.
Also.. I've seen setups with the gen inside mounted next to a wall, and a small opening in the wall for you to just open a small hatch and slide in the pto shaft for hookup while the tractor stays outside.
Another option is to have your connection point outside, or have a hookup cable long enough to make it fron the gen to the hookup point. I made a 20' cable to use with my gen so I can use it other places on the farm.. even in some areas where the tractor can't get super close to.
</font><font color="blue" class="small">( Power always goes out at a bad time. It might not always be convenient to hook the gen up to the tractor )</font>
No different than dragging your dedicated genny out and then pulling the fridge/freezer away from the wall, and running a few extension cords around the house for a light or TV... a pto gen hookup can be as simple as 4 points if on a carrier with an attatched pto shaft.
</font><font color="blue" class="small">( You might wan to use the gen where your tractor isn't )</font>
So far that is about the best argument, and one of the major trade offs.. portability. Course you usually have a wattage trade off that goes with that. One that is small enough to be easilly portable, is lower wattage. My pto gen is obviously married to the tractor.. but has lots of capacity...
</font><font color="blue" class="small">( I think the portable has more pros than cons )</font>
That's a subjective decision. There is one more engine to maintain.. and your tractor engine is probably a more reliable engine.. or hopefully is. Your tractor engine is also well suited for long run times, and has a higher fuel capacity than a standalone unit. More oil capacity.. and an oil filter. I've only seen a few small engines with oil filters. All this adds up to longer engine life. Another thing.. a pto gen runs the tractor at a rated rpm.. like pto rpm. A small gass engine is more or less running full out to get the rpm needed for the genny.. that usually means decreased life due to stress. Not to mention that your tractor may have extra 'reserve' hp for heavy load situations. For instance.. a 25 hp lawnmower engine is just not the same as a 25 hp tractor engine.
Soundguy
/ PTO Generator
Thanks for all the input. I checked the previous posts and there is a wealth of info to go over. Thanks again.
/ PTO Generator #8
Just sent you a private message... I researched Generators for months before deciding on the PTO genset thanks to the wealth of knowledge from people like SoundGuy and others on this forum.
What I needed was an awesome, "Clean" power solution that would run everything I had and more without any doubts. I did pay twice as much than the Box Store gas unit I was originally going to purchase but it is money well spent.
Have a great day,
John
/ PTO Generator #10
Sorry... I should have mentioned that I went with the GenPower 15/35kw unit. They run about $2500 last time I checked.
John
/ PTO Generator #11
Your photo shows the exact unit I just had delivered to my door complete with shaft, power cord, 3-pt frame (nice), dual meters, electronic voltage control, shock mounted instument panel/control box, for 1860 complete with shipping.
/ PTO Generator #12
</font><font color="blue" class="small">( Your photo shows the exact unit I just had delivered to my door complete with shaft, )</font>
If you don't mind, where did you get yours from? Thanks, John
/ PTO Generator #13
Direct from the Power Connection. Others on this forum have listed their website address. I have their 800 number, but its at home. I could post it Monday.
/ PTO Generator #14
Thanks, I managed to find the 800 number, but no website.
1-800-895-9981 The Power Connection
John
/ PTO Generator #15
Ask for Jerry. He knows his stuff. Tell him you read about it on TBN. I told him yesterday that we were talking about his product on TBN.
I will be spinning mine up this weekend for the first time. I wired my cord last nite. /forums/images/graemlins/smile.gif
/ PTO Generator #16
</font><font color="blue" class="small">( I will be spinning mine up this weekend for the first time. I wired my cord last nite. )</font>
Cool! Let us know how it goes. Thanks for the info. John
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
2010 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2010 CHANDLER TRI...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
2017 FORD TAURUS 4 DOOR CAR (A66091)
2017 FORD TAURUS 4...
2014 CHEVROLET CAPRICE CAR (A66091)
2014 CHEVROLET...
Welcome to the Ranch Metal Decorative Sign (A64557)
Welcome to the...
