Generator PTO Generator
/ PTO Generator #81
He is right. I have a Bachelor Degree in Aeronautics. Its called parasite drag or parasitic.
Parasitic drag - Wikipedia, the free encyclopedia
My next door neighbor had a 28' 7,000# bumper pull camper and pulled it with a 2005 F-150, got 10 mpg. He upgraded to a 2007 D-max 3500 and got 12 mpg. He was truly disappointed but it was not the trucks fault. They were in the market for a 35' Goose Neck last winter and I looked at them all with him. The ones with a smooth finish and a rounded back is what I suggested. He end up with a 38' with the features mentioned and a weight just shy of 14,000# empty. He has taken the new one about 7,000 miles last summer and averaged 11.5 or just slightly worse than the old camper that was half the weight and 10' shorter.
Chris
/ PTO Generator #83
Hmm.. I wouldn't automatially ssume that a lawnmower engine is going to be superior in fuel economy to a nice diesel tractor.. remember.. rpm of your tractor is not what uses fuel.. it's hp used.. p used will be determined by electrical load.. that load, in an equal comparison to the 13hp gasser nd the diesel.. just because yor engine is rated at 49 hp does not mean you are making it if.. say.. it only needs 13 hp... that means your fuel usage should pretty closely track hp usage.
I know my 12hp rider lawnmower DRINKS gas compaired to my larger diesel tractors looking at work done.. ie. amount of grass cut. 5g of diesel cuts 10ac of pasture for me... that rider cutting those 10ac will suck down a whole lot more than 5g of gas!!.. I've never been able to get more than an hour of runtime out of a gallon of gas on that rider... and it'l take a whole lota hours to cut 10ac .. so you can see where that fuel savings theory just went! Fuel used pretty closely tracks work done on n average diesel... that same 5g of fuel oil runs my 95hp/15' mower for 2 hours.. or the 70hp/10' mower for about 3 hrs... both eilding a 10ac cut.... I've used the 95hp tractor on the 10' mower used the same fuel and ran the same amount of time as the 70hp tractor..
soundguy
I believe if you will reread my thread you will notice that one of the differences I noted was that the generator will go down to an idle and when you are not pulling any apreciable current. As the current demand goes up then it will speed up the motor on the generator. The tractor does not have that capability so it will be running at full rpms any time you are using the generator. The governor will make some difference but basically it will not be sitting at an idle until you need it. I have not checked to see how long my tractor will run with 7 gallons of fuel but the generator will do somewhere between 10 and 12 hours maybe longer depending on how much electricity I use. I also believe there is a difference in price of almost 1.00 per gallon locally. since gas here is running about 1.90 a gallon on the average that is going to make a huge difference in computing the cost.
/ PTO Generator #84
The only problem is that there would have to be NO load on the generator. If you're powering a house that will not happen. If you are powering a few items like a well and furnace, yes it may go to idle until a load is detected. Depends upon how you are set-up to power your needs.
/ PTO Generator #85
Sure. You're adding a trailer with a bunch of wind resistance and a handful of tires. Pretty much what I said above.
Think of an over-the-road semi with a dry van trailer. It can double its weight when loaded, and still stay within 10% of its unloaded milage. Or Boneville Salt Flat racers. Those cars are heavy as heck, but very slippery.
Nobody has proven Newton wrong yet.
It does seem like I can get about the same mileage pulling a trailer whether the trailer is empty or full.
I'll support your claim about Newton as long as it's understood to only apply in a macro physical world. Atomic physics deviate a little bit.
/ PTO Generator #86
I have a 540 and a 750 setting on my Kubota (50 - hp). When I run my 16 k generator I have found that the 750 setting with the tractor idled back to 540 rpm will not govern itself close enough to work well.
So the 750 pto gearing is 1-1 with the crank shaft?, if I got that right, or do you mean engine idled back so pto is turning the required 540 rpm. I believe there would be trouble governing a huge load but what about a 5 kw draw, with your 50hp and 16 kw gen, couldn't it handle that?
Regarding the idle control on the portables, it works fine for a construction site when there is only intermittent power needs, pick up the saw the gen speeds up, put it down and she idles down, as was mentioned that doesn't really come into play in the home, even with a 10 watt light on the thing is gonna be turning 3600 rpm's
Anyway, I enjoy the generator debates, looks like there is no perfect choice for everyone as needs differ, opinions? that's a different story, gets a little testy sometimes, but still civil.
JB.
/ PTO Generator #87
that was covered in post 75
/ PTO Generator
Got an email from them stating that it is backordered and they don't have a ship date yet.:(
/ PTO Generator #90
I have a 8550 watt Troy Built that I used for 8 day straight once, and two other times for 3 days at a time. It will run 24 hours on 9 gallons of fuel. I have a well, but propane for the furnace and hot water. We have 2 fridges and a deep freezer plus the wife used the stove (1 burner at a time) the micro, garbage disposer and the crock pot with no problems. We use the garage door opener, were smart with the lights but keep the tv and the satellite going.
Chris
/ PTO Generator #91
The generator you describe, DC/inverter type is only now becoming commonplace, probably due to their price(but they sure are nice though:)). The honda's I have looked at do offer a very nice inverter output. With some added circuitry, they can also be combined/paralleled to increase your system capacity. This comes back to the horsepower used. An idleing generator is moving less air thru it's blower and consuming less HP. They are also firing less times per minute at that reduced load RPM. That however is about the only thing that gets the gassers competive with the diesels. Diesel also has quite a few more BTU than gas does, so more potential work is available in each gallon of diesel.
/ PTO Generator #92
I dont believe i have a dc inverter type of generator. I do however I am sure have a monitor that if I am not useing any current or just a small amount (I have not checked to see) it sets the rpms at idle. If the load goes up then the motor changes to full rpms. Since I have not done any tests to see what happens and how long it will actually run I dont have empirical facts to back my estimates up. If we assume the price of gasoline at 2.00 a gallon and the price of diesel fuel at 3.00 a gallon then we can make the assumption that if my generator runs 12 hours on a tank of gas which is 7 gallons then we could assume the same amount of money spent for 7 gallons of diesel would buy us aproximately 10.5 gallons of gas. now if we can run for 12 hours on 7 gallons of gas then we should run approximately 18 hours on 10.5 gallons of gas. Because of the price of diesel we are only going to have 7 gallons of gas for the 49 horse montana. Now I am not an expert on how much difference work makes versus just idleing but If you dont use any diesel when you are not doing work then my tractor should be able to run at 2400 rpm's ( 540 pto speed) for ever without my having to fill the tank. That obviously does not happen. Actually i kind of thought that if the tractor was running 2400 rpm's it takes a certain amount of fuel to fill the cylinder to get 2400 rpms so it is going to use some fuel. I would be totally amazed if I could set my tractor out there with no load ( even though the generator would be a load not sure how much of one it would be for a 49 horse tractor) and run for 18 hours at 2400 rpm on 7 gallons of diesel. It might and i have never tried it but it would amaze me.
/ PTO Generator #93
4] ~6.5 : 1 gearboxes [3600/540] are pretty inefficient. Much nicer to have an 1800 rpm gen -- or else one designed for 1000PTO.
larry
Good point.. the more poles the better ( and more $$ ).
soundguy
/ PTO Generator #94
I agree.. I drove 2260 miles round trip to texas at easter.. used a ford f250 diesel.. pulled an empty 16' trailer up.. got 14.1 mpg total.. pulled that rig back with a 3000# tractor on it.. got 14 mpg back...
soundguy
/ PTO Generator #95
I think you are missing the point.. generated alectricity is frequency dependent.. and that is rpm dependent.. to get that machine to idle down.. I'm betting it has to have -0- load.. otherwise it wouldn't be making the correct frequency power... I don't let my gennies set and run if there is no load for extended times.. thus the idle down argument is less attracive.. since my tractor engine uses NO FUEL when i turn it off ( when i don't need electric ).. vs your idled gas engine using some fuel when you aren't making power.. well.. I'm sticking to my original argument..
soundguy
/ PTO Generator #96
If it is not an inverter type.. then it's all or non on the current / idle issue.. since at idle the frequency of the generated power would be way wrong.. thus if it s flowing ANY current.. it's not idling.
If it was an inverter type.. then it would be expensive to get one with much cpacity.. let along anything near what a 13hp engine could kick.. ie easilly in the .5kw range.. an inverter that big would be expensive.. plus need a decent battery to suck on. Inverter's throw additional ineficency into the mix...
Like I said.. I'll stick tot he diesel engine vs the lawnmower engine.. vs the inverter ...
soundguy
/ PTO Generator #97
Yea, but I unhook that trailer and take the camper off the truck so shouldn't the Fuel Mileage just go to astronomical levels if it's about HP required.:D
By the way fellows, all those degrees aside, have any of you ever heard of topography relief! :D
/ PTO Generator #98
Yep. For every uphill there's a downhill. For the extra fuel burn on the way up, you'll get that much free energy on the way down. I'll get my best towing mpg when I'm in the mountains, which was a surprise the first time I experienced it. But it does make sense, considering that I'm 10-20 mph slower in the mountains than I am across the plains, and that my net elevation change is zero.
Wanna start another thread about towing mpg in the proper forum and give this guy his thread about generators back?
/ PTO Generator #99
[QUOTEWanna start another thread about towing mpg in the proper forum and give this guy his thread about generators back?QUOTE]
Never deviated. Thought fuel economy was brought into play as part of the issue or did you miss that?
You fellows always in the habit of ignoring facts if they don't suit your opinions:confused::confused:
/ PTO Generator #100
soundguy
you are probably right about the 0 current. I have not tried it so I dont know. but your arguement on that point makes sense. I guess your arguement goes back to what you are going to use the power for. If you are going to have a generator running so that you can have power for lights or tv or whatever then you can start the generator and have it run when you need it and turn it off when you are done. I believe I could do the same thing with my genrator. However if you are going to have power available so that you can turn on a light or power a fan for a heater. Then you are going to need to leave the generator running and my idle down feature on the generator would be a lot better. Luckily for both of us they make and sell both kind of generators so that we can both be satisfied with our choice whichever one is better.
2020 INTERNATIONAL MV607 S/A 26FT NON CDL BOX TRUCK (A59911)
2020 INTERNATIONAL...
2024 Schulte 5026 Batwing Rotary Cutter (A63688)
2024 Schulte 5026...
KIVEL 3500 PALLET FORK ATTACHMENT (A61572)
KIVEL 3500 PALLET...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2019 Ford Transit 350 Police Transport Van (A61573)
2019 Ford Transit...
48x4 Mini Skid Trencher (A63689)
48x4 Mini Skid...
