Generator PTO Generator - Lights Flicker
/ PTO Generator - Lights Flicker #41
Good suggestion Tommu. If it is still under warranty he might void that if they think he is inside of the unit.
/ PTO Generator - Lights Flicker #43
I think the thread was reopened with this new generator.. Yeah I would want that long of a warranty also.
/ PTO Generator - Lights Flicker #44
Five year warranty on Tiger-Power Generators according to their website. I will have to double check my paperwork. The dealer who sold it to me is no longer a registered dealer, but that may not matter.
The unit is brushless, so that rules out that possibility, but good suggestion.
I hope to monkey around with it tonight, again, weather permitting.
/ PTO Generator - Lights Flicker #45
I'd call them first Im sure they have some suggestions
TollFree (800) 779-8809
Local (717) 274-8899
/ PTO Generator - Lights Flicker #46
old thread ..
I have a similar flicker with a 6500/5500 watt gas standby generator. I only have a meter that reads voltage and it is rock steady at 120V.
It is not the tractor. Like one of the posters said it is probably the regulator in the genset.
If I load up the generator it smooths out the flicker ..but my microwave doesn't like it at all. I also have a 10kw output from a Lincoln welder which uses an inverter (Kubota diesel powered) and it does not have the flicker.
I would be interested if there is a fix to the flicker issue that isn't too costly.
cheers
/ PTO Generator - Lights Flicker #47
I have not had problems with incandescents, but man the fluorescents don't like home made power.
JB
/ PTO Generator - Lights Flicker #49
Power Surge Protection for Computer Systems and Home Electronics | Tripp Lite
HowStuffWorks "How Surge Protectors Work"
If your lights are flickering you can be weakening equipment that is sensitive to line frequency and power stability. A decent suppressor should help smooth that out. Google them and see what you find.
Yes electronics don't like fluctuations.
I would want to put it in line to the power coming into the house. That would probably cost me more then the generator is worth. The Lincoln is my main backup which doesn't have problem.
thanks
BETTER BUILT FUEL CELL (A58214)
BETTER BUILT FUEL...
2014 Freightliner 105' Bucket Truck (A61307)
2014 Freightliner...
2017 Infiniti QX60 SUV (A59231)
2017 Infiniti QX60...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
Giyi GY-CYHC Mini QA Side Shift Forks (A60463)
Giyi GY-CYHC Mini...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
