Generator PTO Generator - Lights Flicker
/ PTO Generator - Lights Flicker #41
Good suggestion Tommu. If it is still under warranty he might void that if they think he is inside of the unit.
/ PTO Generator - Lights Flicker #43
I think the thread was reopened with this new generator.. Yeah I would want that long of a warranty also.
/ PTO Generator - Lights Flicker #44
Five year warranty on Tiger-Power Generators according to their website. I will have to double check my paperwork. The dealer who sold it to me is no longer a registered dealer, but that may not matter.
The unit is brushless, so that rules out that possibility, but good suggestion.
I hope to monkey around with it tonight, again, weather permitting.
/ PTO Generator - Lights Flicker #45
I'd call them first Im sure they have some suggestions
TollFree (800) 779-8809
Local (717) 274-8899
/ PTO Generator - Lights Flicker #46
old thread ..
I have a similar flicker with a 6500/5500 watt gas standby generator. I only have a meter that reads voltage and it is rock steady at 120V.
It is not the tractor. Like one of the posters said it is probably the regulator in the genset.
If I load up the generator it smooths out the flicker ..but my microwave doesn't like it at all. I also have a 10kw output from a Lincoln welder which uses an inverter (Kubota diesel powered) and it does not have the flicker.
I would be interested if there is a fix to the flicker issue that isn't too costly.
cheers
/ PTO Generator - Lights Flicker #47
I have not had problems with incandescents, but man the fluorescents don't like home made power.
JB
/ PTO Generator - Lights Flicker #49
Power Surge Protection for Computer Systems and Home Electronics | Tripp Lite
HowStuffWorks "How Surge Protectors Work"
If your lights are flickering you can be weakening equipment that is sensitive to line frequency and power stability. A decent suppressor should help smooth that out. Google them and see what you find.
Yes electronics don't like fluctuations.
I would want to put it in line to the power coming into the house. That would probably cost me more then the generator is worth. The Lincoln is my main backup which doesn't have problem.
thanks
BOOM FOR HYDROVAC TRUCK (A68842)
BOOM FOR HYDROVAC...
Unused 2022 USA Attachments EB-618 18in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2022 USA...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
2014 CATERPILLAR 320EL RR EXCAVATOR (A65056)
2014 CATERPILLAR...
2020 VOLVO VNL760 SLEEPER TRUCK (A59914)
2020 VOLVO VNL760...
2002 SUPERLINE DO20T242LP T/A 24FT TRAILER (A66091)
2002 SUPERLINE...
