PTO Driveshaft
/ PTO Driveshaft #1
tld
Boston, GA
JD 2025r
I have a JD 4110 with a small BushHog mower. When connecting to driveshaft to the PTO spline, I need to remove 3 white connectors that keep the guard on. These are about 1.5 inches long and have a slot on top to turn with screwdriver. You turn it counterclockwise and pull it out. The guard then slips back.
Problem....all of these white connectors have been lost.
I know this is an older model, but does anyone know:
1. what is the part name for these?
2. Where can I get them?
3. Is there an easier to use guard where I don't have to use these connectors?
/ PTO Driveshaft #2
I beleive I have seen them at Tractor Supply. My one shaft uses a plastic piece that pops up to release the guard, no parts to lose but not sure if you retro fit it.
/ PTO Driveshaft
Found them at JD store. Shield bolt/fastener. Was on the Bush Hog schematic they had. 2 dollars each and I am back in cutting.
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2008 EZ-GO GAS GOLF CART (A63276)
2008 EZ-GO GAS...
2013 GMC Sierra 4x4 (A62613)
2013 GMC Sierra...
Massage Chair (A65640)
2022 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2022 FREIGHTLINER...
