PTO Driveshaft
/ PTO Driveshaft #1
tld
Boston, GA
JD 2025r
I have a JD 4110 with a small BushHog mower. When connecting to driveshaft to the PTO spline, I need to remove 3 white connectors that keep the guard on. These are about 1.5 inches long and have a slot on top to turn with screwdriver. You turn it counterclockwise and pull it out. The guard then slips back.
Problem....all of these white connectors have been lost.
I know this is an older model, but does anyone know:
1. what is the part name for these?
2. Where can I get them?
3. Is there an easier to use guard where I don't have to use these connectors?
/ PTO Driveshaft #2
I beleive I have seen them at Tractor Supply. My one shaft uses a plastic piece that pops up to release the guard, no parts to lose but not sure if you retro fit it.
/ PTO Driveshaft
Found them at JD store. Shield bolt/fastener. Was on the Bush Hog schematic they had. 2 dollars each and I am back in cutting.
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
2023 New Holland Powerstar 90 Tractor (A65579)
2023 New Holland...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
