PTO Drive shaft alignment
/ PTO Drive shaft alignment #1
professorburnout
Hollsopple PA
Kubota B8200 HST
Hello,
I recently purchased this flail mower but it is not totally right for my tractor. I wanted to find out if the alignment of the PTO drive shaft is OK to be about 3-4 inches off alignment from the center line of the tractor PTO shaft? I was thinking of welding new mounts on the mower to get the PTO shaft aligned but I was not sure if this would be necessary.
Thanks,
Paul
/ PTO Drive shaft alignment #2
That should be find. I have a BearCat chipper that is off-center more than that.
gg
/ PTO Drive shaft alignment #3
The manual that came with my wood chipper says to run the pto shaft at a 15 degree angle or less.
/ PTO Drive shaft alignment #4
It's the angle, not the offset, that affects universal joint longevity. So if ericm979's PTO shaft was similar to yours with your 4 inch offset, than any shaft longer than about 15 inches (between u-joints) would be less than 15 degrees.
Angle=arcsin(offset/u-joint distance)
Also, that offset is the total offset, not just horizontal or vertical offset but their combined effect. That can be calculated too.
John Deere 6200 Tractor (A64047)
John Deere 6200...
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
Kubota KX080-4 Mini Excavator (A65579)
Kubota KX080-4...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2015 New Holland 560 Round Baler  5x6 Bales (A63688)
2015 New Holland...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
