PTO Dash Light not working
/ PTO Dash Light not working #1
sanchezm
DeWitt, Michigan
John Deere 855
Hello All, I own a JD 855 Compact Utility Tractor. My most recent problem with it is that the PTO warning light on the dash will not come on when the PTO is engaged. The PTO works fine, but the warning light will not come on. I replaced the light bulb with a brand new one and it made no difference, still no light when the PTO is engaged. I am thinking it is an electrical problem of some kind. Any thoughts or fixes will be appreciated. Thank you, Mark.
/ PTO Dash Light not working #2
I have the same issue i cant figure it out. You can search my threads and see if that helps you.
/ PTO Dash Light not working #3
Need to find the sender/switch and make sure it is working properly. If it is check the wire from the switch to the light. You may find the switch just got bumped out of alignment or is full of dirt.
/ PTO Dash Light not working #4
The lamp indicator switch is located on the rear of the transaxle, below the dipstick. Make sure the wires have not come off the switch. You can also remove the wires from the switch and use a jumper to short the terminal of the harness to test the switch. If the light comes on when you jump the harness, then the switch is bad.
Thanks for all the suggestions guys. I will check the switch as mentioned in the replies I received.
John Deere 6200 Tractor (A64047)
John Deere 6200...
Troy-Bilt Pony Riding Mower (A65579)
Troy-Bilt Pony...
FORD 2810 TRACTOR (A64277)
FORD 2810 TRACTOR...
2013 Land Rover Range Rover AWD SUV (A64557)
2013 Land Rover...
Great Dane Van Trailer (A63689)
Great Dane Van...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
