PTO coupler "frozen"
   / PTO coupler "frozen" #1
bcjmmac
NB, Canada
John Deere 2520
In November I was going to bush hog the back 40 with my Houzz but the coupler wouldn't move (some wet areas back there so easier to cut when it is either very dry or ground is frozen). Was fairly cold (-10C) so took it off but couldn't get it to loosen up after a few hours indoors. Sprayed with penetrating oil & stuck it back on the pto shaft. Went out the other day & it is working fine so expect there may have been some ice in there. Other than storing the coupler part of the shaft indoors, what do other people do?
   / PTO coupler "frozen" #2
If it moves, grease it. If it doesn't move, paint it.
Let's see if we can get this thread to 40 pages!!
   / PTO coupler "frozen" #3
Store everything inside. Stops rust too.
   / PTO coupler "frozen" #4
store with it tilted up so moisture cant get in .
   / PTO coupler "frozen" #5
I store the PTO shaft with both U-joints inside a shed. Its dry but not heated. Seldom have problems with rust here in Ea WA. Our humidity is so very low.
   / PTO coupler "frozen" #6
I sometimes just wrap a plastic bag around it and tape it to keep water out. It doesn't look pretty but it works every time for me.
DEWFPO
2011 PETERBILT 389 (A50854)
2011 PETERBILT 389...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2015 FORD F750 BOX TRUCK (A51219)
2015 FORD F750 BOX...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
Heavy Duty Skid...
