PTO coupler "frozen"
   / PTO coupler "frozen" #1
bcjmmac
NB, Canada
John Deere 2520
In November I was going to bush hog the back 40 with my Houzz but the coupler wouldn't move (some wet areas back there so easier to cut when it is either very dry or ground is frozen). Was fairly cold (-10C) so took it off but couldn't get it to loosen up after a few hours indoors. Sprayed with penetrating oil & stuck it back on the pto shaft. Went out the other day & it is working fine so expect there may have been some ice in there. Other than storing the coupler part of the shaft indoors, what do other people do?
   / PTO coupler "frozen" #2
If it moves, grease it. If it doesn't move, paint it.
Let's see if we can get this thread to 40 pages!!
   / PTO coupler "frozen" #3
Store everything inside. Stops rust too.
   / PTO coupler "frozen" #4
store with it tilted up so moisture cant get in .
   / PTO coupler "frozen" #5
I store the PTO shaft with both U-joints inside a shed. Its dry but not heated. Seldom have problems with rust here in Ea WA. Our humidity is so very low.
   / PTO coupler "frozen" #6
I sometimes just wrap a plastic bag around it and tape it to keep water out. It doesn't look pretty but it works every time for me.
DEWFPO
1270 (A50490)
1270 (A50490)
WASTE OIL TANK (A50854)
WASTE OIL TANK...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2021 Isuzu NRR Heil 9Yd Mini Rear Loader Garbage Truck (A50323)
2021 Isuzu NRR...
2012 Ford F-150 Crew Cab Pickup Truck (A49461)
2012 Ford F-150...
2012 Ford F-250 Ext. Cab Omaha Service Truck (A50323)
2012 Ford F-250...
