PTO coupler "frozen"
   / PTO coupler "frozen" #1
bcjmmac
NB, Canada
John Deere 2520
In November I was going to bush hog the back 40 with my Houzz but the coupler wouldn't move (some wet areas back there so easier to cut when it is either very dry or ground is frozen). Was fairly cold (-10C) so took it off but couldn't get it to loosen up after a few hours indoors. Sprayed with penetrating oil & stuck it back on the pto shaft. Went out the other day & it is working fine so expect there may have been some ice in there. Other than storing the coupler part of the shaft indoors, what do other people do?
   / PTO coupler "frozen" #2
If it moves, grease it. If it doesn't move, paint it.
Let's see if we can get this thread to 40 pages!!
   / PTO coupler "frozen" #3
Store everything inside. Stops rust too.
   / PTO coupler "frozen" #4
store with it tilted up so moisture cant get in .
   / PTO coupler "frozen" #5
I store the PTO shaft with both U-joints inside a shed. Its dry but not heated. Seldom have problems with rust here in Ea WA. Our humidity is so very low.
   / PTO coupler "frozen" #6
I sometimes just wrap a plastic bag around it and tape it to keep water out. It doesn't look pretty but it works every time for me.
DEWFPO
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
2015 MACK CHU613 TRI-AXLE (A50854)
2015 MACK CHU613...
2006 CMI C125-1 Ride-On Forestry Mulcher (A49461)
2006 CMI C125-1...
2013 F-550 Bucket Truck (A52128)
2013 F-550 Bucket...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2019 Ford F-450 4x4 Crew Cab and Chassis Truck (A49461)
2019 Ford F-450...
