Mowing PTO clutch
/ PTO clutch #1
rodburner
Catlettsburg Ky
cub cadet 2166
I have a cub 2166 mower.The PTO gets very hot and ruins the belts after a few cuttings. the dealer said nothing wrong but it is not right. what can cure this?
/ PTO clutch #2
PTO needs to be lubed? Belts too tight? Misaligned belts?
/ PTO clutch #3
The bearings are probably siezing in your electric PTO.
Isn't hard to replace, but the price will knock your socks off.
The only 2 other problems I had with my old 2160 (regarding belts), is that sometimes the belt would twist on the vertical pulleys below the front of the engine and burn up the belts.
2nd problem was the belt tension on the deck itself, the belt would stretch just a tad, and although the tensioner would take up the slack..........the back of the belt would rub on the bracket that connects the deck to the tractor. A brand new belt would leave about 1/16 of an inch of clearance.
2013 Ford Focus Sedan (A61574)
2013 Ford Focus...
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
(2) UNUSED 10-16.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 10-16.5...
Rightline LP5C-C5B0-A 42in Hydraulic Side Shift Forks and Frame Forklift Attachment (A61572)
Rightline...
2010 Scag STT52V-27CH 52in Zero Turn Mower (A61572)
2010 Scag...
1000 Gal Tank (A64119)
