Mowing PTO clutch
/ PTO clutch #1
rodburner
Catlettsburg Ky
cub cadet 2166
I have a cub 2166 mower.The PTO gets very hot and ruins the belts after a few cuttings. the dealer said nothing wrong but it is not right. what can cure this?
/ PTO clutch #2
PTO needs to be lubed? Belts too tight? Misaligned belts?
/ PTO clutch #3
The bearings are probably siezing in your electric PTO.
Isn't hard to replace, but the price will knock your socks off.
The only 2 other problems I had with my old 2160 (regarding belts), is that sometimes the belt would twist on the vertical pulleys below the front of the engine and burn up the belts.
2nd problem was the belt tension on the deck itself, the belt would stretch just a tad, and although the tensioner would take up the slack..........the back of the belt would rub on the bracket that connects the deck to the tractor. A brand new belt would leave about 1/16 of an inch of clearance.
2015Ford Escape SUV (A61574)
2015Ford Escape...
ABI 80-ASRT-074 Command Seeder Tractor Attachment (A61572)
ABI 80-ASRT-074...
2013 Ford Escape SUV (A61574)
2013 Ford Escape...
2017 NISSAN NV2500 4x2 VAN (A59911)
2017 NISSAN NV2500...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
2012 Can-Am Spyder Motorcycle (A61574)
2012 Can-Am Spyder...
