PTO Clutch Replacement
/ PTO Clutch Replacement #1
FairportCub
Hi guys. I have a Cub 1863 with an 18 HP Kohler. I am going to change the PTO clutch this spring. Is it a hard job? Or is it as easy as it looks? Anything I need to know? Tricks?
I appreciate anything you can give.
/ PTO Clutch Replacement #2
It's not real hard to change out, but once the new on is on you have to set the air gap to the right measurement and make sure it is even all around. This is done using the three spring loaded nuts with a feeler gauge between the rotor and the armature. As these clutches are very expensive, I recommend getting a hold of a service manual to see what the correct air gap is and see exactly how to do this as it differs between the models.
-Fordlords-
/ PTO Clutch Replacement #3
MAny of the newer set-ups come preset and it would be a good Idea to double check when purchasing your new clutch.
/ PTO Clutch Replacement #4
I have the 1864 manual. If it's the same as the 1863, I can look it up/post.
In fact, I recall this manual IS for the 1863 (there is no 1864 specific manual).
-Larry
Thanks for all the advice guys. I don't have a service manual for my tractor. So, if you could post that gap spec. from the 1864 manual that would be great!
/ PTO Clutch Replacement #6
Early 1863's serial numbers 836,001-880,000 use the old style adjustable PTO clutch. If this is your case you can use the procedure for the 1862 in the online manual here IHRegistry Home to set the air gap to .017".
If you have a later 1863 serial numbers 880,001-899,000 your tractor will use the newer style PTO clutch assembly that bolts on without requiring adjustment.
Hint :) The older adjustable ones if adjusted right are the better PTO clutches IMHO.
-Fordlords-
Wow great info! I appreciate it. I have the older style one. So, that's good to know they're a little better. This is the first time it's been replaced since the tractor was new.
/ PTO Clutch Replacement #8
Ok, I see it's already covered :)
BTW.. You can buy an entire set of manuals for about $50 from C&G.
-Larry
2020 FORD F-150 XL CREW CAB TRUCK (A65054)
2020 FORD F-150 XL...
2020 Doosan DX35 (A64911)
2020 Doosan DX35...
2006 W-W TRAILER 20' T/A ENCLOSED TRAILER (A67714)
2006 W-W TRAILER...
1995 John Deere 8300 (A64911)
1995 John Deere...
2021 Vermeer STR48 Hydraulic Trencher Attachment (A64912)
2021 Vermeer STR48...
2009 HEIL CRUDE PUP TRAILER (A67714)
2009 HEIL CRUDE...
