PT425 T8 to mini skid (Dingo) adapter?
   / PT425 T8 to mini skid (Dingo) adapter? #21
Sometimes I think about taking a fitting out of the line, weld it closed and drill it out with a smaller diameter to slow it down some.
   / PT425 T8 to mini skid (Dingo) adapter? #22
They make flow restrictors ;)
   / PT425 T8 to mini skid (Dingo) adapter? #23
You sound like my Urologist :p
   / PT425 T8 to mini skid (Dingo) adapter? #25
Have you done anything with this? If you can't find a cheaper adapter, the Eterra is nice looking. Just get a PT blank adapter for your machine, get the angle off your bucket's mounting area in relation to the ground and have it welded on. That small Dingo adapter cost more then the SSQA to 3pt hitch adapter that I used to make mine.
Nothing yet, but hopefully I can find time in the next couple of weeks to fool with it.
   / PT425 T8 to mini skid (Dingo) adapter? #27
Does that mean you have a plan?
I am planning on ordering one of the Eterra Mini Skid adapters and picking up a blank PT female plate when go up to Tazwell. I need to go up there to get a brush cutter anyway.
   / PT425 T8 to mini skid (Dingo) adapter? #29
Don’t just buy one. Implements are very addictive. Qa plates a relatively cheap. I built 5 to begin with and then made another 5 of which 3 are left
   / PT425 T8 to mini skid (Dingo) adapter? #30
Take lots of pics and show dimensions of the build.
2012 DOOSAN G25 GENERATOR (A58216)
2012 DOOSAN G25...
CAT D5G LGP DOZER (A58216)
CAT D5G LGP DOZER...
CUMMINS 230 KW GENERATOR (A58375)
CUMMINS 230 KW...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
12' Container W/Side Door and Window (A57149)
12' Container...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
