PT425 Grapple Build Project
/ PT425 Grapple Build Project #61
Re: PT425 Grapple Build Project Picture
All right yous guys! I'm trying to keep this under $200.00. /w3tcompact/icons/laugh.gif
But I still look at the links for great ideas... thanks!! /w3tcompact/icons/smile.gif
/ PT425 Grapple Build Project #63
Mossman,
Perhaps I missed it amongst your many posts /w3tcompact/icons/wink.gif, but is your toothbar (looks quite stout) a homemace job, a PT option or did you acquire it elsewhere.
Through overly exhuberant newbie digging and dirt and heavy rock moving efforts, I've managed to bend my big bucket almost beyond recognition...it has to go to the welding hospital for reshaping and stiffening...., so now I am looking to add a toothbar to the small one before I trash it too! /w3tcompact/icons/laugh.gif
Thanks for this grapple thread...I'm getting inspired!
I don't think you can call it a tooth 'bar' as they are just teeth that are individually bolted onto the bucket. I ordered them through Power Trac for $100.00 installed.
I welded the 3point hitch ends onto the top rear of the small bucket. They look pretty good. I went out and bought a cheap 1/2 inch drill press and grinder at Harbor Frieght as well. I needed the drill press to drill the holes for the pins in the grapple arms and cylinder brackets and the grinder to clean up some of the tack welds and spatter. Harbor frieght sells some pretty cheap stuff, and it might not last too long, but a 4-1/2 grinder for $17.00 and a 1/2 inch benchtop drill press for $39.00 was just to good to pass up. Even it they only last for this project, they are well worth the price. It was too dark for pictures and it is supposed to rain until Saturday, so I'll take pictures ASAP this weekend. /w3tcompact/icons/smile.gif
/ PT425 Grapple Build Project #66
i fully understand your desire to build a grapple bucket as soon as possible. what a geeat help for the rest of us. i and my two small businesses would be lost without the grapple bucket.
i hope that randy lackender will take my suggestion to incorporate a grapple like i found for atv log loaders ( i think i sent you a website address to you under separate cover and posted it on TBN). if the guys at lackender can somehow come up with a grapple at the end of the backhoe (not just a thumb) where you can control hyraulically both sides we/i am in seventh haven. at times the grapple bucket is too clumsy when you try to segregate different things
I saw that link. I agree that a grapple at the end of an arm could be quite usefull. And to make it interchangeable with a hoe bucket would be a dual purpose machine.
Drilled the holes in the end fingers to hold the 3pt hitch pins today. Also cut and tack welded one set of cross members. Test fit looks OK. Need to saw off some extra length from the rear of the fingers, true up the cross pieces, test fit again, then weld them in. Will try to post pictures in the next few days.
Here's what I have so far. Still need some bracing and have to figure out the hydraulic cylinder loaction and size.
I tacked on the rear post for the hydraulic cylinder this afternoon. Used vice grips and a tape measure to guestimate that I will need approximately 8" cylinder. Now to surf the bailey's site with a credit card /w3tcompact/icons/tongue.gif
/ PT425 Grapple Build Project #73
David,
What is Bailey's site. Is it a hydraulics supplier. Could you post the address.
What type of end connections are you going to get on the cylinders. Power Trac seems to like the spherical bearing end connections on their cylinders, I'm not sure commercial term is for this type of end connection. From the hydraulic catalogs I have looked through, the spherical bearing type does not appear that prevalent.
Duane
/ PT425 Grapple Build Project #74
Duane, try <A target="_blank" HREF=http://baileynet.com/>http://baileynet.com/</A>
You are an early riser, Bird /w3tcompact/icons/laugh.gif
Bailey's has LOTS of good hydraulic stuff. I'm pricing the cylinder there. Looks like about $65.00 + shipping. I just can't find one locally with an 8" stroke. I'll get the hoses and connectors locally (hopefuly)
/ PT425 Grapple Build Project #76
Mossroad, Any progress on this project you can share with us? If there isn't I can relate, I have only got to spend about 6 hours on my pole barn project in the last 3 weeks.
Nothing to report... it is all put together except for the cylinder, cylinder mounts and hoses with quick connects. I have my eyes on a cylinder at Bailey's, but have to wait a few weeks for the holiday sticker shock to wear off before I spend any more of my money.... but you guys feel free to spend it for me, OK? /w3tcompact/icons/tongue.gif
/ PT425 Grapple Build Project #78
MossRoad
It's been almost a year since you have posted any progress on your Grapple project. /forums/images/graemlins/cool.gif
Have you completed it and do you have any pictures? /forums/images/graemlins/smile.gif
Holy cow! Time flies, doesn't it? Forgot all about it, to tell you the truth. /forums/images/graemlins/grin.gif Nothing has come up that I need it for yet.
It is done except for still needs cylinder(s) and hoses to complete. It opens and closes on the planes that I wanted. Will be handy for spring cleanup, so I better finish it over the winter. I'll have to check out the Surplus Center again to see if they have a cylinder that will suit my needs. I want something with a shorter profile than I can find at TSC. Hmmm....
/ PT425 Grapple Build Project #80
Any idea what the bucket and grapple will weigh complete?
I have another question. When PT says 800 pounds lifting capacity is that net or gross. I ask because none of their literature tells how heavy the different implements are so it's tough to tell what the useful lifting capacity is.
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
New 10' Cattle Working Chute (A62679)
New 10' Cattle...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63688)
2023 New Holland...
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
2019 CATERPILLAR TL642D TELESCPOPIC FORKLIFT (A62129)
2019 CATERPILLAR...
