PT422 First Engine Oil Change
/ PT422 First Engine Oil Change #1
duane
Toro 266H and PT422
The Robin Engine manual says to change the first oil at 20 hours. I'm used to changing it at less hours on a new engine. What did you guys do?
Duane
/ PT422 First Engine Oil Change #2
What do they recommend after the first change?
PJ
/ PT422 First Engine Oil Change #3
every machine that comes into our shop we change after 5 hours over to synthetic oil, especially the one that always or most the time run at full trottle i.e. mowers etc.
/ PT422 First Engine Oil Change #4
Duane,
What part of Maine are you from? I am looking to purchase a 422 possibly next week and I am in Saco.
/ PT422 First Engine Oil Change #5
Ah, so someone does use synthetic oil in the engine! I was thinking about that. Should significantly prolong the engine life. What weight should I use in my Briggs 18HP V-twin?
Dave
/ PT422 First Engine Oil Change #6
we use whatever is recommended by the manufacturer as far as weight goes. my exmark has the identical eng as the pt and they authorize 100 hours per oil change
Accu-Line 110V Tire Changer (A64556)
Accu-Line 110V...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
2018 Land Rover 4WD SUV (A61574)
2018 Land Rover...
2013 FREIGHTLINER CASCADIA T/A 6X4 DAY CAB TRUCK (A67147)
2013 FREIGHTLINER...
2003 Freightliner FS65 Thomas School Bus (A64194)
2003 Freightliner...
213085 (A64276)
213085 (A64276)
