MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,033
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
The Kohler in my PT425 model year 2001 starts reliably at ZERO degrees provided I have a good battery and spark plugs. I also give it one shot of ether below 20 degrees before attempting to start. Above 20 degrees, I just hop on it and crank. My original battery lasted 6 years! I need a new starter solenoid right now, after 9 years and 400 hours.
The PTs have the added burden of spinning both the engine and hydraulic pumps when starting, no matter which engine they have. I do nothing special to start mine, like warming the engine, battery or hydraulic tank. Only below 20 do I give it the shot of ether. I think ours failed to start one time since 2001. I'd have to go back and search my posts over the years.
I was kind of sickened to recommend the Power Trac PT425 to so many people and then have so many people report cold starting problems when PT switched away from the Kohler engine.
I wish they would go back to the Kohler. Apparently cold weather is not a problem in VA.
I like the idea of a fuel injected engine VS carb, but have no idea how they work in the cold on small engines like ours. I know my 93 Chevy Suburban has throttle body fuel injection and starts at all temps. So did my 93 Chevy van at -22. Virtually every car in the last 15 years has fuel injection and they all start. It would be nice if the small engines worked the same.
Be sure to put some stabil in the gas cans as soon as you fill them at the station.
Put some heat fuel treatment in there, too, in the winter.
Keep the battery charged.
Remove and clean your battery connections before winter.
Check your plugs before winter starts.
Fully choke the engine, start cranking, then increase the throttle until it goes BANG! :thumbsup:
