PT422 Engine shaking / sputtering
/ PT422 Engine shaking / sputtering #121
I need to point out again that my new PT 425 (Dec 2010) with the EH72D had no starting problems even in an unheated garage at 15 degrees F. I reemenber reading a post on the PT Forum from Jack Robin a few yars ago. He is a Subaru/Robin rep. He said that the newer Robin engines were enhanced to fix the starting problems with the older PT 422/425 tractors. He said that there were bigger batteries, more powerfull starters, hotter plugs ...
I have had bad luck with two 25 HP CH730 in 2 Sears (Huskvarna) GT 5000 Garden Tractors. Both engines failed after three years. Upon inspection found had broken pieces of the cylynder walls ... An Internet search found others having the same problem. My next Sears tractors have B&S engines.
This is good to know... maybe the reliability differences are all in my head. (?) Thanks for your input.
What do you guys think about the advantages/disadvantages between the fuel injected and the normal EH72? I think it is about $300 more for the FI version.
/ PT422 Engine shaking / sputtering #123
If you've encountered either hard starting (either hot or cold) or vapor locking/sputtering when it is hot, fuel injection would address those problems...
/ PT422 Engine shaking / sputtering #124
I think I'd have to agree with that. But then you have a computer to deal with, don't you? I hate computers. It is EFI, correct? That means electronic and that means dead electronics eventually. Has anyone heard anything negative about the electronics on these engines?
/ PT422 Engine shaking / sputtering #125
The FI version is 27 HP right? If I had a choice when buying my PT-425 I would have paid $300 extra just for the +2 HP. I recommend doing a search for issues with the FI version...
/ PT422 Engine shaking / sputtering #126
Well my only experience is with Kohler, but I have good luck with that engine. I have run EFI in mowers and loved the ease of starting. My local shop told me that ever since the EFI Kohler has come out he has only had one come back with EFI problem, while having to work on many carbs during that same time. Just food for thought.
/ PT422 Engine shaking / sputtering #127
The FI engine is rated at 28hp, but there's a catch: The 28 (actually 27 & a bit)hp is at 4000 rpm. At 3600, the graph shows just about 25hp.
/ PT422 Engine shaking / sputtering #128
Yeah but how is the 25 hp motor rated?
/ PT422 Engine shaking / sputtering #129
Thanks Gravy, for pointing that out. There's always a catch isn't there.
I don't mind if it is 25hp since it's going into a PT422... Even though Terry said a 25hp motor would be fine in this machine, I'm worried if it gets up to 28 or so that its too much for the pumps, etc. I don't know if that is a genuine concern or not, but I didn't want to take the chance.
I'll probably order the EH72FI this week and put it in sometime in April.
/ PT422 Engine shaking / sputtering #131
Just set the max RPM to 3600.
/ PT422 Engine shaking / sputtering #132
You can not over power a pump, It runs at the engine rpm and will pump up to the volume and pressure designed into the pump. The GPM's are related to engine rpm, but the pressure is based on the resistance to the hyd flow, whether it is a cyl or hyd motor.
You can under power a pump and it will stall the engine.
I have three pumps on my 1445, a small steering and lift pump, a med size pump for PTO, and the VSP pump for the hyd wheel motors. They were selected to utilize the available HP
/ PT422 Engine shaking / sputtering #133
The relief valves help protect the pumps and the rest of the hydraulic system.
Well, I'm pulling the trigger and ordering the EH72 Fuel Injection. They now have a 1 7/16" shaft version (in addition to the 1") for a $100 up-charge, but it should mate with the coupling I have currently. It's approximately $400 more than the standard EH72.
/ PT422 Engine shaking / sputtering #135
We must have details on the installation (pictures, drawings, parts list, and comments). Also a report on the performance. Thanks in advance. Sounds like you made the right choice. My Robin engine has about 900 hours on it, so I am not real far behind you.
/ PT422 Engine shaking / sputtering #136
KMA,
You may have to hacksaw the crankshaft stub to length, and buy a new Lovejoy coupler half, but other than that it should be pretty straightforward. As far as I can tell, it's the same basic engine with EFI grafted onto it. I guess you will also have to add a return line to the fuel tank, and maybe splice a wire or two.
I'm betting that you will be delighted with the power and easier starting. If not, I bet you will let us know.
Thanks guys. Yeah I will do my best to document the process and post up results.
Gravy, regarding the lovejoy coupler... can I expect to reuse the existing one if it is the same shaft size? I ordered the 1 7/16" shaft vs the 1" shaft to keep it the same as the previous engine and so it would match up with the coupler.
Thanks again all. :)
/ PT422 Engine shaking / sputtering #138
You should be able to use it if the shafts are the same size.
Thanks. :thumbsup: I hope it matches up. There's only a few hundred hours on the machine so I'm hoping everything is still in decent shape and can be reused.
I ordered my engine from Equipatron.com since one of the owners (Pete) has been quick to answer my questions over the last several months. He told me I can expect it to arrive sometime next week, but I don't think I'll now for sure until the freight company calls to arrange the drop off. Hopefully the weather breaks here soon and gets warmer. It was 8 degrees when I woke up this morning... :confused2: Ah... springtime in upstate NY!
Update:
I received my EH72FI in three business days, and it even included lift gate service which surprised me. I'm trying to take pictures to document the swap and I have the old motor pulled. It turns out the EH65 had a 1 1/8" shaft (and not the 1 7/16" I was led to believe). So I need to order a new coupling. I wish I figured that out earlier since I could have ordered the new engine with a 1" shaft and saved $100. Oh well...
I'm hoping someone here might know more about these couplings than I do... I need a coupling with 1 7/16" bore and 3/8" keyway. The current coupling is 2.5" in diameter and and about 2" long. I think the Lovejoy "L" series would work but I'm having trouble tracking down the complete specification and dimensions for the various models. Here's a link to the pdf file I've been looking at (page JW11). There appears to be 5 models with 1 7/16" bore shown about 3/4 of the way down the page.
http://www.google.com/url?q=http://...780092&usg=AFQjCNH1Pba9WmHBiXFyGUwd6EQXJHuB3A
L110 11746
L150 12114
L190 12295
L225 12431
L276 12591
What do you guys think? Does anyone know of a better resource? Thanks again for everyone's help so far.
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2022 EZ-GO ELITE...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
2134 (A65055)
2134 (A65055)
2022 EZ-GO ELITE...
1NOP 2002 CLUB CAR ELECTRIC GOLF CART (A65055)
1NOP 2002 CLUB CAR...
