PT422 electrical diagram
   / PT422 electrical diagram #1
Marks481
Platinum Member
Power Trac 422 (2005)
Anybody have an electrical diagram for the PT422? I checked the manual, and I have nothing.
In the right side of the engine compartment I have two connectors which are unplugged. A female bayonent connector on a white wite which has 12V when the ignition switch is on, and a male bayonent connector on a gray wire. Anybody know what these do? The tractor runs fine without plugging them into each other.
   / PT422 electrical diagram #2
Get an engine manual for your engine and it should show you what those are for.
I had some spare wires hanging off of my Kohler, and the Kohler manual had them identified.
Good call. The Robin America site had all the manuals online, and the engine manual had the diagram. The gray wire is the oil low pressure alarm. Sure enough, the oil pressure sensor wire is gray. I am thinking that I will hook it up.
   / PT422 electrical diagram #4
I hooked up the oil pressure switch to a light that I added on the console. I think it is a really good idea. The light sometimes flickers at low idle and I know to up the idle speed a little.
   / PT422 electrical diagram #5
Great! :)
LMC G500-500A LOT NUMBER 216 (A53084)
LMC G500-500A LOT...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
MURRAY 20" SIDE DISCHARGE GAS PUSH MOWER (A51248)
MURRAY 20" SIDE...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
(3) VISSANI REFRIGERATORS (1) FRIGIDAIRE REFRIGERA (A51248)
(3) VISSANI...
