PT warranty issues.
/ PT warranty issues. #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
Have any of you needed to hire a mechanic to fix something while still under warranty?
PT said they would send out parts, but then they wash their hands. Are these machines built so well and simple that the servicing is way easier than normal?
I think the PT 425 looks like it will do everything that I want around the yard. I just felt uncomfortable about not having any dealers anywhere.
Yooper Dave
/ PT warranty issues. #2
I have about 112 hours on mine and haven't had to do anything to it yet, except filters, lubrication, etc... There really isn't much to the machine. It is two solid steel sections all welded construction with a joint holding the two sections together. There are about three steel plates that have to be removed once in a while for maintenance, but that is just a few bolts. The engine is a Kohler(in the PT425) and if you have a good small engine shop or lawn mower place, they should be able to do any major engine repairs for you, should they arrise. The hydraulic pumps are bolted onto each side of the engine. Again, there are a few bolts and hoses to deal with. The rest of the machine is just hydraulic cylinders, hoses and joints. There is not too much to it. I think my tool kit for the PT now includes one crescent wrench, one grease gun, a roll of paper towels, a bottle of Simple Green cleaner and a garden hose with nozzle. It really is a simple, well thought out machine. If you are comfortable working on cars, boats or lawn mowers, you would have no problems working on a PT, should something major happen.
There are several people here on TBN that have done some major repairs. Hopefully they will chime in. /forums/images/graemlins/smile.gif
/ PT warranty issues. #3
The Kohler engine can repaired under warranty by any authorized Kohler service shop. I think you will find at least one convenient to your location. You can go to the Kohler Locater Page and plug in your zip code to check.
We have had our PT-425 just under three weeks. The machine now has 15.5 hours on it. So far I have had to fix a seeping gas tank that wasn't assembled correctly (PT should look into that tank supplier) and shim a hydraulic fitting so that the connecting hose's fitting didn't rub on the tilt crossarm. That took about 30 seconds.
I have also played with the parking brake, which is stiff, and pulled the steering wheel, which I would like to replace. Neither of the latter were items that I had to do.
I don't see anything on the machine that requires a dealer in the sense that a standard tractor does. The hydraulic pumps and motors can be serviced by any competent hydraulic shop, should the need arise.
The electrics are extremely simple, with no complicated wiring harnesses. The only starter interlock is the PTO switch.
It seems to me that someone with a modicum of mechanical skills--and common sense--should be able to live fine with a PT, but I wouldn't recommend one to someone who doesn't know the difference between a box wrench and a bagel.
SnowRidge
/ PT warranty issues. #4
I am not a mechanic. I messed with cars when I was young and even replaced some bearings, but changing oil and spark plugs was as far as I would usually go. I too had some reservations about lack of dealer network, but was so sold opn the idea of a PT that I bought a used PT2445, trailer and implements.
I farily quickly had to become hands on to replace some busted hoses. The good news is, after a few frustrating and intimidating hours of wrestling with the snake's nest of oily hydraulic hoses, unfamiliar parts, tight connections and slippery knuckle busting wrenches, I was able to calm down, work methodically, make sense of it and get the job done. I have since replaced a half dozen hoses and now consider it no big deal.
If you responsibly monitor and maintain your engine filters, fluid levels and grease regularly, there is really very little to go wrong with a PT. Replacing an occasional hose is inevitable. Any tractor or hydraulic mechanic can do it, or you can tackle it yourself. Getting replacement hoses is easy....many auto supply houses like NAPA will custom make them.
The folks at the PT plant are very knowledgable and helpful on the phone. And, if you ever have to send the PT off for major repairs, I have found them to be very fair and capable.
Sabi
/ PT warranty issues. #5
Yooper Dave,
If you can tell us what kind of tools you have (and have used in the past), this panel of "expert estimators" can probably tell you ,with a high degree of certainty,
if you're PT "qualified". /forums/images/graemlins/grin.gif
...This may be the easiest way to put your mind at ease...
/ PT warranty issues. #6
I am a new owner--less than two months and have had no significant problems. I thought about the same issue prior to buying. As previous responders have indicated most issues can be dealt with by changing out components and that is straight forward so long as you are comfortable doing the component changes. I think the biggest issue about lack of a dealer is that the owner has to manage any major repair issues--you have to identify the shop that can deal with the component and you have to remove the component to take it to the shop or have the means to transport the entire tractor to the shop. With a dealer you have the option of calling the dealer and letting him manage major repairs.
Hi Bruce,
I mostly have carpentry tools, but have maintained several pieces of turf equipment at my parents golf course over the past 25 years /forums/images/graemlins/grin.gif.
I know how to get myself in a heap of trouble in a hurry.
Toro commercial turf equipment is as complicated as I have ever seen. Simplicity in design sure gets me excited /forums/images/graemlins/smile.gif.
I am still trying to get a cost for shipping from Scott at PT.
Are they good at following up?
Thanks
Yooper Dave
/ PT warranty issues. #8
I have owned my power trac 422 for over three years and close to 500 hours of use. I have never had any problems with it other than the mower tire going flat and a gas leak on the gas tank filler lid .
/ PT warranty issues. #9
<font color="blue"> I am still trying to get a cost for shipping from Scott at PT.
Are they good at following up? </font>
They are great with phone support for repairs and technical questions, but the business of selling them sometimes makes me wonder. /forums/images/graemlins/crazy.gif
If they don't return your call after a day, I'd call them and ask for a shipping quote again. I went through similar experiences with them. Instant tech support, but slow business response. Very odd. I didn't take offense to it, but wondered if they were just too busy or a little disorganized on the business side of the office. Oh well. As mom always said, "Good things come to those who wait." /forums/images/graemlins/smile.gif
/ PT warranty issues. #10
</font><font color="blue" class="small">( have maintained several pieces of turf equipment at my parents golf course over the past 25 years . )</font>
Well, I believe you're technically qualified, now...let's see,...what else,... /forums/images/graemlins/smile.gif
</font><font color="blue" class="small">( I know how to get myself in a heap of trouble in a hurry )</font>
Ah!!! Humble, too!...That'll come in handy when total strangers come up and admire your prowess in selecting a very unique piece of gear... /forums/images/graemlins/grin.gif
On the shipping quote...The receptionist(her name escapes me now) was the person actually gathering the quote info when I was there...Just ask her when you call up if she can get the quote for you.(rather than waiting on sales to call back)
Yooper Dave,
It's still a haul, but I'm an hour or so south of Rockford if you want to make a run down some weekend and take a test drive (on a 422)...
/ PT warranty issues. #11
other than the engine (head gasket) problem, which Kohler covered anybody can do in a weekend, you may need your partners two hands in addition to yours to fiddle some hoses through a tight spot but otherwise just one level above bicycle mechanics. /forums/images/graemlins/grin.gif
/ PT warranty issues. #12
I don't own a p.t. yet but I expect to pretty soon. The ability to fix it myself is one of the main positives I see, especially after dealing with the local Toro service center . Their typical time to just look at my machine has been 5-6 weeks this time of year, and it's very difficult to find a book on fixing Toros as well.
/ PT warranty issues. #13
Hello Bruce! /forums/images/graemlins/smile.gif
Sandwich, huh? I hear you guys have a pretty good flea market down there on occassion. Some have even said that it's better than Kane County's! /forums/images/graemlins/ooo.gif
The wife and I have talked about coming down there to check it out for ourselves. Is it worth the trip? Might even consider taking a peak at your PT too, if we could work that out! /forums/images/graemlins/wink.gif
/ PT warranty issues. #14
Hi Garry,
My wife (the expert in these matters) tells me that there is a very good antique "market" the end of every month in the summer. She adds that it IS better than Kane County, too.
There's one this weekend, I think, too.
By all means- come on down some time-you can demo the PT.
Send me an email if you want to hook up.
She's headed up to E. Troy tomorrow for a rug hooking class.
Where abouts are you in S.C. Wisc.
Regards,
Bruce
/ PT warranty issues. #15
</font><font color="blue" class="small">( Where abouts are you in S.C. Wisc.
)</font>
I be in Janesville, <font color="green"> The City of Parks </font>. We're only about an hour and half away from your area.
We've been down to Kane County a number of times, but haven't had the chance to get over to Sandwich yet.
This weekend is out, as we have to go to Chicago for our niece's high school graduation party.
Thanks for the offer for the demo. If we see we can get down there, the wives can go to the antique market and we can play, er, demo your PT! /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif
/ PT warranty issues. #16
</font><font color="blue" class="small">( Thanks for the offer for the demo. If we see we can get down there, the wives can go to the antique market and we can play, er, demo your PT! )</font>
Anytime...
BK
2021 LiuGong 9027FZTS Mini Excavator (A64553)
2021 LiuGong...
2013 Ford F-350 4x4 Crew Cab Pickup Truck (A64556)
2013 Ford F-350...
2022 Timpte T/A Super Hopper Grain Trailer (A64194)
2022 Timpte T/A...
(4) 265/65R18 TIRES & 5 LUG RIMS IN BOXES (A64278)
(4) 265/65R18...
2025 Sprit Scooter (A64557)
2025 Sprit Scooter...
3PT SPRAYER RACK (A64278)
3PT SPRAYER RACK...
