PT Rises from the Ashes
/ PT Rises from the Ashes
Edward_DiMaria: <font color="red"> Hey Sedgewood - is Columbia traqctor the guys I see at the Dutchess County Fairn every year? - I assume you go to it - Most of those folks who present there are really good folks
</font>
I'm not a fairgoer but I would think they would be there. Good people. I've been dealing with them at least since 1967 and maybe even before that.
Sedgewood
Marrt: <font color="green"> I think most folks who buy PT's like to “improve/modify” their equipment. I know I do. Trying to determine the optimal filtration for the PT, even though it may not make sense financially given the actual risk/design life of the tractor, is just part of the fun. </font>
Now THAT'S spot on! /forums/images/graemlins/laugh.gif
And the idea of a severe duty option seems like a good profit center too. Charlie, Hans, and I tried on our visit last fall (without much success I fear) to convince them of the potential profits in after sale accessories and upgrades. These are enthusiasts / tinkerers machines and we like to add stuff. Think of the money to be made in gimballed cupholders and rear view mirrors.
Oh yeah, gotta get back to my mirror project now that I have a tractor again,
Sedgewood
duane: <font color="red"> John, after you have worked your 1845 machine hard, could you post some hydraulic reservoir temperatures along with the ambient temperatures. Curious to see where the bulk temperature settles out at. </font>
I haven't gotten in enough seat time yet for anything definitive. At the moment I'm running the hydraulic cooler fan backwards (cause I accidentally hooked it up backwards and this gives me a chance to test whether the concept will help reduce chaff getting into the engine compartment) which kind of skews things toward the high side. I think the highest I've seen was 140 degrees at about 70 degrees ambient.
Sedgewood
/ PT Rises from the Ashes #44
<font color="red"> What caused you to use a vacuum gage rather than a pressure guage?
Uh... the filter is on the suction side and there's a vacuum there?
</font>
Sorry for the dumb question. There was another thread that pointed to the Graninger catalog for RETURN LINE FILTERS AND ACCESSORIES. Apparently the same filter mount (and filter??) is used for both suction lines and return lines.
<font color="red"> I seem to recall seeing somewhere (on Gesen web site perhaps) that the relief valve is set at 3-5 psi </font>
At the risk of asking another less than brilliant question--how does a relief valve set for pressure work in a vacuum situation? I purchased the NAPA 1759 filter as a replacement and according to the WIX site this filter does not have a relief valve. And this filter is listed as a cross for the Parker filter carried by Grainger for return line applications.
/ PT Rises from the Ashes #45
<font color="blue"> At the risk of asking another less than brilliant question </font>
Boy, don't start worring about that!!! You're in good company with me hanging around here /forums/images/graemlins/tongue.gif
Bob999: <font color="red"> Apparently the same filter mount (and filter??) is used for both suction lines and return lines. </font>
Yes, except, and this is important I would think, when you use it as a suction side filter you have to change the relief valve spring (it's in the housing, not the filter element - I think the Sauer Danfoss article on cleanliness talks about it and has a cross sectional drawing of a housing) to a much lighter spring, in the range of 3-5psi instead of 15psi as I recall.
<font color="red">At the risk of asking another less than brilliant question--how does a relief valve set for pressure work in a vacuum situation? </font>
The relief valve is sensing the differential pressure across the housing - the pressure difference (caused by the restriction to flow of the filter element and its collection of dirt) between the inlet side and the outlet side. It don't care if you're suckin' or blowin' your oil through it. /forums/images/graemlins/tongue.gif
Sedgewood
/ PT Rises from the Ashes #47
<font color="blue"> Just a guess, but I'll bet this is it. </font>
Yep, betcha there's no show girls there. Sorry Terry /forums/images/graemlins/frown.gif
/ PT Rises from the Ashes #48
This is the annual mining show which PT said they display the mining equipment as primary product but this year will also bring a few tractors to show the above ground product.
PJ
/ PT Rises from the Ashes #49
I think the return line filtration is quite adequate. However it won't protect from slag in the tank, only a suction strainer would help there. If you want additional piece of mind then parker and many others have several filters to choose from down to 3µm, rated at or above 25gpm. If you add the 3µm filter then I think the pressure guage would also be a good addition.
/ PT Rises from the Ashes #50
<font color="red"> I think the return line filtration is quite adequate. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif </font>
My understanding is that PT units have a SUCTION line filter for the variable displacement pump.
My further understanding is that PT units have no filtering on the PTO and auxiary PTO circuits and that they have no suction line screens anywhere in the system.
/ PT Rises from the Ashes #51
</font><font color="blue" class="small">( I'm running the hydraulic cooler fan backwards (cause I accidentally hooked it up backwards and this gives me a chance to test whether the concept will help reduce chaff getting into the engine compartment) )</font>
John,
That's something I've been wonderin' about, too...but then I complicated it (on the design napkin) with a dpdt switch (or relay) so the fan could be reversed "for cleaning"...now you've got me thinkin' /forums/images/graemlins/shocked.gif that there would be real cooling benefits to permanently running it backwards.
/ PT Rises from the Ashes #52
<font color="red">( I'm running the hydraulic cooler fan backwards (cause I accidentally hooked it up backwards and this gives me a chance to test whether the concept will help reduce chaff getting into the engine compartment) )
</font>
I will be interested in the results. I have no problem with chaff since I taped screen over the rear panel of the enclosure and changed to a side discharge mower deck. I get some chaff on the screen material in a circle that exactly corresponds to the intake for engine radiator air cooling but it simply brushes off. I have not had build up on the hydraulic oil cooler since the changes.
One thought about running the fan reversed--if you do get chaff it will be much more difficult to clean.
Bob999 <font color="red"> My understanding is that PT units have a SUCTION line filter for the variable displacement pump. </font>
That's what my unit has.
<font color="red"> My further understanding is that PT units have no filtering on the PTO and auxiary PTO circuits and that they have no suction line screens anywhere in the system. </font>
Right.
Sedgewood
/ PT Rises from the Ashes #54
</font><font color="blue" class="small">( if you do get chaff it will be much more difficult to clean )</font>
Good point...Ahh...Now, with a short wood/metal framework over the top of fan with house screening attached and held on with strip magnets (fridge door style) we'd keep positive pressure in the engine bay(keeping it cleaner) and maybe a cooler (??) environment for engine...
...Not sure if the "clean" factor would be worth the effort , but, a cooler operating environment for the motor would be a worthy goal(??) /forums/images/graemlins/wink.gif
/ PT Rises from the Ashes #55
<font color="red"> but, a cooler operating environment for the motor would be a worthy goal(??) </font>
It seems to me that what is important is that you have cool clean air going to the engine air cleaner and to the engine cooling. On the diesel power units both the air cleaner and the intake for engine cooling are located at the back of the tractor. I think there is a good chance the temperature of the air there would be increased by running the fan backward.
/ PT Rises from the Ashes #56
Do these circuits get sort of "indirect filtering"
since all the fluid in the tank is filtered and that is where
they get the fluid? or is that a stretch?
would it be easy to add and inline filter or would it mess up the flow / pressure? - what are the different types of filtering techniques? - does anyone know - ??
/ PT Rises from the Ashes #57
<font color="red"> would it be easy to add and inline filter or would it mess up the flow / pressure? - what are the different types of filtering techniques? - does anyone know - ??
</font>
I have looked in the engine compartment of my PT 1845 for a place that a filter might be added on the return line of the PTO circuit. This is a 15 gal/min circuit and I have assumed I would use the same size filter that PT uses on the suction line for the variable displacement pump. I haven't come up with a place to put it. I have read that suction line filters are not generally recommended---except--for variable volume pumps.
There are both low pressure (return line) and high pressure (supply line) filters available. Both Grainger and MSC Industrial Supply carry both. High pressure units are much more expensive ($300+) than low pressure ($~70).
<font color="red"> Do these circuits get sort of "indirect filtering"
</font>
PT uses a common reservoir for all hydraulic circuits. The variable volume pump pulls from this reservoir and the return flow is to the same reservoir. My understanding is that this approach is supposed to maintain an "acceptable" cleanliness level. What this approach does not do is ensure that the supply to the other two circuits is clean--this can only be done with suction filters for each of those circuits. It also does not ensure that dirt from any circuit return is kept out of the common reservoir--this can only be done with a return line filter on each circuit. Putting a filter on the supply side ensures that any dirt is filtered before it gets to the motor or cylinder.
Clearly there is a point of diminishing marginal return with adding filters to the system. PT engineers made the choice at one filter in the system of three pumps. No one has really provided any quantitative information about what would be gained from adding an additional filter.
/ PT Rises from the Ashes #58
<font color="blue"> No one has really provided any quantitative information about what would be gained from adding an additional filter. </font>
Measurable gain... no. But if something in any of the hydraulic circuits shreds itself and dumps it into the reservoir, all of the unfiltered circuits will be open to damage. So how do you measure peace of mind? /forums/images/graemlins/wink.gif
Bob999:<font color="red"> I will be interested in the results. I have no problem with chaff since I taped screen over the rear panel of the enclosure and changed to a side discharge mower deck</font>
Guess it's about time I added something here since I seem to have started this discussion about chaff filtering. /forums/images/graemlins/tongue.gif
My mowing is probably a bit different from most, especially this year since I just started the mowing season last week /forums/images/graemlins/tongue.gif
Let's start with a picture from yesterday after 1-1/2 hours into brush hogging an unmowed field. And not a terrifically heavy chaff day at that - the growth didn't include much dry grass es- mostly mature goldenrod etc.
<font color="red"> I get some chaff on the screen material in a circle that exactly corresponds to the intake for engine radiator air cooling but it simply brushes off. I have not had build up on the hydraulic oil cooler since the changes.</font> I say a light chaff day yesterday because I only had to brush off the rear screen half a dozen times in the 1-1/2 hours - instead of the usual double that.
<font color="red">One thought about running the fan reversed--if you do get chaff it will be much more difficult to clean.</font>
I'm not sure it makes much difference - once I determined my cooler was full of last years chaff, way deep inside where you can't see it, it took nearly an hour with the hose to wash it clean. That's from last years stock non-reversed fan setup.
Sedgewood
bmkar: <font color="green"> Good point...Ahh...Now, with a short wood/metal framework over the top of fan with house screening attached and held on with strip magnets (fridge door style) we'd keep positive pressure in the engine bay(keeping it cleaner) </font>
Kind of like this? What you see is a screened "house" (with a solid roof - screens on sides only) taped on the hood. Inside is a piece of furnace filter material lying atop the fan. In the center is a trumpet bell shaped piece of aluminum I thought might redirect the flow.
<font color="green"> ...Not sure if the "clean" factor would be worth the effort , but, a cooler operating environment for the motor would be a worthy goal(??) </font>
Blowing 150 degree air over the engine doesn't seem to help the cooling much. It's running hot as ever.
Sedgewood
2016 280 Trailers Towable LED Advertisement Board (A64553)
2016 280 Trailers...
Wooden Table (A64557)
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
2025 Wolverine MSG-11-44W 44in Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A64553)
2025 Wolverine...
2013 Vermeer Vac-Tron LP855SDT T/A Vacuum Trailer (A64194)
2013 Vermeer...
