PT-422 Fan Temperature Switch
/ PT-422 Fan Temperature Switch #1
Vacuous_One
Saltsburg PA
PT422
Anybody out there have a picture (or, would be willing to take a picture) of the top of the fan temperature switch that shows the text/numbers on it?
Mine's gone missing (the top of the switch, that is) and I want to replace it. While I could go directly to P/T, I've found their spare parts for pass-through items (i.e., "no value added") to be quite high! I'd like to bypass the middle-man on the commodity items, here. But, I need the info to get the right part. So, any help out there?
I searched the forums and found only a few references to this switch. "Woodlandfarms" had a posting ("What is this") where the first photo was of the switch, but it was from the side and I can't read the text.
Thanks for any help anyone can provide.
/ PT-422 Fan Temperature Switch #2
Not the best picture, but it's something. I believe this is a clothes dryer temperature switch, but it closes when it gets hot.
Bob Ripley
/ PT-422 Fan Temperature Switch #4
Does anyone seem to have any trouble with these. I replaced mine 3 times. It would go about every tank full. Then i got tired of that and just hot wired it so the fan was always on. Any thoughts from anyone would be appreciated.
/ PT-422 Fan Temperature Switch #5
I replaced mine once in 850 hours. Can you check your fan current? Maybe something is wrong with it. It should pull about 5 amps. Maybe it's not the switch. Did you check to see if the switch closed when hot? Could be a loose connection. Check you spade lugs and see if they are loose where crimped.
BobRip & frischtr:
That identifies it...White-Rodgers Therm-O-Disc Snap Action Fan Control switch, Series 60T, model 3F01-120. Closes at 120F, opens at 110F.
Now, to get one and do the replacement!
Thanks so much for your gracious help!
  • White-Rodgers - Snap Disc Fan Controls - Cat_06_pg0091.pdf
/ PT-422 Fan Temperature Switch #8
Mine stopped working about 350 hours. I also hot wired it so it is always on.
/ PT-422 Fan Temperature Switch #9
I went through 2 than hot wired it on in Summer and off in Winter. I plan to wire in a toggle switch some day.
/ PT-422 Fan Temperature Switch #10
I talked to the manufacturer of the switch today. The switch being used is not rated for DC. They do have a switch rated for DC, but only one amp. The fan pulls about 5 amps. I would recommend that if you care, put in a relay that is driven by the switch. The relay then controls the fan. I am at 850 hours and have replaced the switch once. I would say that's not too bad. I will continue to replace it. It does not cycle much so it does not wear out too quickly.
I think it is probably not good to cool the system in cold weather. It would increase the warm up time. With a switch, I guarantee that I will forget to turn it on during at least one hot day, and probably many. I don't see how this increases the PT life. As such, I will keep replacing the switch. I guess I am due.
/ PT-422 Fan Temperature Switch #11
You are correct that the thermostat switch is not used much. Once it comes on, it stays on until I am done working. I have never ever witnessed it cycle off once it comes on. I put a little piece of orange safety tape on my fan shroud so I could tell when it came on. The little tape flaps around and I don't have to reach around to feel the air flow.
/ PT-422 Fan Temperature Switch #13
I have the same switch on my 1460, and I just ran a current clamp on it, and it pulls 7.4 amps DC. I guess I should look at a new solution, or expect to be switching this thing out a lot. I will give Terry a call and see what he thinks.
/ PT-422 Fan Temperature Switch #14
That temp sensor, is nothing more than a make or break function. The fan is what is drawing the current. I doubt if those temp sensors fail that often. Once the fan comes on, it will probably stay on.
/ PT-422 Fan Temperature Switch #15
It still last longer than a spark plug. Just keep a spare and replace as needed. Not a perfect solution, but not a crisis either. I have never seen one cut off once it cut on.
/ PT-422 Fan Temperature Switch #16
I know that, I was just stating the amps of the fan on the 1460, that's all. The higher the fan current, the more trouble the temp sensor will be. If people are having trouble with the 5 amp fan on the 422, I am probably going to have trouble even sooner. It is a very easy fix with a relay, so I think I will go ahead and get one.
2020 PETERBILT 567 (A60736)
2020 PETERBILT 567...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
New/Unused CFG Industrial QK18R Mini Excavator (A61166)
New/Unused CFG...
2001 VERMEER E550 VACUUM (A60736)
2001 VERMEER E550...
2008 BOBCAT T320 SKID STEER (A62129)
2008 BOBCAT T320...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A60352)
2013 Chevrolet...
