PT 1445
/ PT 1445 #11
Re: PT 1445
Keep in mind that with a PT you can apply down pressure while you are relying only on gravity with a 3ph on a CUT. Still, a BB on a PT is not one of their better attachements although it probably works better than it looks.
/ PT 1445 #12
Re: PT 1445
<font color="red"> PT's boxblade is light and the one for the 1445 is only 270 lbs. Consequently, the BB on comparably powered CUT could work better. </font>
I bought a 6ft SBX720 Bush Hog box blade for my 1845 which if memory serves me right weighs 535 pounds. I used it for a year or so as is then laid an old log wagon axle across the top which must weigh close to two hundred lbs. The thing works much better now, but it's still only marginally heavy enough to limit chatter in ripping the hard stuff. Heavy is good in a box blade.
Sedgewood
/ PT 1445 #13
Re: PT 1445
That is true, and there is only so much down pressure you can apply with a PT before the front wheels lift. One can add balast to the PT BB, but it is not real easy.
/ PT 1445 #14
Re: PT 1445
<font color="red"> That is true, and there is only so much down pressure you can apply with a PT before the front wheels lift. One can add balast to the PT BB, but it is not real easy </font>
And less down pressure means more weight on the wheels for traction.
Sedgewood
2014 Chevrolet Tahoe SUV (A59231)
2014 Chevrolet...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A59231)
2009 Mariah SC23...
New/Unused CFG Industrial QK18R Mini Excavator (A61166)
New/Unused CFG...
Ratchet Straps (A59230)
Ratchet Straps...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2013 Ford F-150 Pickup Truck (A59230)
2013 Ford F-150...
