Protecting Nuts & Threads
/ Protecting Nuts & Threads #1
ctpres
BAR BOB Ranch, Needville Texas
Kubota 3400HST
Just saw a neat idea and don't remember reading it here. Melt bowl wax ring on nuts and bolts for rust prevention and easy removal later. Got that from an engineer.
/ Protecting Nuts & Threads #3
I'd ask a plumber...
And it may be a trick. Toilet bolts are usually brass.
I got this from a plumber: Never bite your fingernails..
There'a an anti-seize compound that they have for lug-nuts. Don't know if it would work on LBrown, though...
Jake
/ Protecting Nuts & Threads #4
For metal-to-metal I like Permatex 80078 Anti-Seize compound. It's messy as all get out if you get it on you or your gloves, but it sticks like crazy and won't wash off. Get the bottle with the brush-in-the-lid. It coats threads really well.
I do use wax, too. I carry a candle in my woodworking toolbox for whenever I need to drive a screw into a drilled hole. Just rub the threads against the candle to apply. Reduces the twisting effort to drive it in and also helps prevent buggered slots if it ever needs removing.
-Jim
/ Protecting Nuts & Threads #5
I work in aerospace industry, we often apply a dab of silicone to the end of bolts after installation to work as a cheap lock nut in high vibration areas.
Much easier than drilling and tie wire, but yet comes right off with impact.
/ Protecting Nuts & Threads #7
Stockholm Tar , a hundred years later the nuts and bolts will still undo easily .
Well, I, for one, was looking for a reason to go to Stockholm anyway... Wouldn't mind remindin' me when I get there what I went for, would'ja mate?
Jake
/ Protecting Nuts & Threads #8
I use the Never-Seize that looks like silver grease. It even works in high temperature applications like exhaust manifolds. Oh, you can get it here in the USA without going overseas. ;)
/ Protecting Nuts & Threads #9
Not still thinkin this is about 'nuts' on 'threads', are ya there Mike?
/ Protecting Nuts & Threads #10
Stockholm Tar = Pine Tar
No need for international air travel, try a local sporting goods store. But I'll STICK with Never-Seize.
SimS
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2022 Chevrolet...
2011 FORD F-150 (INOPERABLE) (A67714)
2011 FORD F-150...
2015 Evinrude G-2 250hp Outboard Boat Motor (A66738)
2015 Evinrude G-2...
2019 JCB 409-T4 WHEEL LOADER (A65056)
2019 JCB 409-T4...
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2017 FREIGHTLINER...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
