Protected Valve Stems
/ Protected Valve Stems #1
SpringHollow
Elite Member
South of Rochester, NY
Power Trac 1850, NH 2120
I have been planning on welding pipe or metal to keep my valve stems from ripping out. I have never had this problem but it has happened frequentoy to others. Before i put my expensive sealer in, i figured i had better do something.
Searching for metal valve stems, i found these recessed valve stems which might be a neat solution so I ordered them:
Amazon.com: Flush Mount Chrome Valve Stem System (Set of 4): Automotive
They are meant for fancy rims but might be a neat solution to the problem. I want to sandblast my rims but once i do, i will give them a try. Inflating the inner duals would be a pain but with the sealer, that should be a rare occurrence.
/ Protected Valve Stems #2
Just a word of caution if you decide to weld colars on the rims instead...
Welding on any rim with a tire mounted (even deflated with the bead broken) can have explosive results. Always completely dismount the tire first.
YouTube - Tire Explosion
http://www2.worksafebc.com/PDFs/investigations/IIR2005108320019.pdf
http://www.forestryforum.com/board/index.php?topic=42557.0;all
/ Protected Valve Stems #3
The last one I posted was actually the video I was looking for and has much more information than the earlier ones.
Thanks
Thanks for the warning! I am aware of the problem of welding on a rim with a tire attached. I have seen it mentioned here but I must admit it would have never occurred to me to even try doing it.
Ken
/ Protected Valve Stems #5
Ken
Good deal. I looking forward to hearing how those new stems work out.:thumbsup:
/ Protected Valve Stems #6
It looks like they have made them even shorter now.I have used steel stems on my truck for many years. I only had one failure, due to jerk at tire repair shop. They never rot or Blow-out of wheel. I might just order some for my Bota. Thx. Jy.
Hi JY,
These are not normal metal valve stems but recessed metal valve stems
I just test fit one on a beat up spare rim I have and it looks like they will work. I can not say they will not leak yet but there was enough clearance that the cap nor the nuts hit the rim.
After I actually ry them, I wll let you know how they do.
Ken
Now the big question is, can i remove the valve stems from these in order to add the tire sealer.
Ken
just checked to see - the internal valves in the stems look like they can be removed just like normal stems
/ Protected Valve Stems #9
Do you need a special air chuck to put air in the tire?
No, but you need to thread on an extension tube before you can add air. The extension has a piece of metal in it that presses down on the internal stem when you press down on the extensions internal stem with your air chuck.
I really am hoping that this works out because it is a nicer solution versus welding on pipe or plate protectors. Pure luck that i happened to see them and realized that they might work.
Ken
/ Protected Valve Stems #11
Ken
Just order a couple extra of those threaded extensions. If my luck with lost tire gauges is any indicator of what would happen to those tubes. ;)
/ Protected Valve Stems #12
It hasn't been long but I was wondering if you tried these and if you liked them
All I did was try them in a dented up rim. I will have to wait until snow season is over before i can afford to take the duals off.
Ken
/ Protected Valve Stems #14
Well it has been a while and I wondered if you habe tried these yet. It looks like a good solution. I ripped a valve stem off yesterday moving brush around so....
I have been using them for about 7-8 months now in 4 of my tires with no problems. Ia m glad I installed them. But these tires now have the bullet proof sealer in them so I have not had to add air. To add air, you have to screw in a supplied extension.
Ken
Just an update: I still have not had to add air to the tires because of the sealer. Before the sealer, I was adding air every week or so due to rim leaks etc. No issues with the valve stems but then I have not had to use them to add air.
Ken
